Home » Archived » Test and Performance Tools Platform (TPTP) » Problem with verification hooks
Problem with verification hooks [message #91886] |
Mon, 29 January 2007 18:09 |
Originally posted by: dkurtz.nospam_olenick.com
So, I'm following the tutorials in "Introduction to Using TPTP's Autmated
GUI Recorder" and am at the section on creating verification hooks. I've
followed all the steps. After adding the code to the VerifyImport method of
the generated VerificationClass.java, I had a number of "cannot resolve to
type" errors on the LogViewer and related classes, which I fixed by letting
Quick Fix add an import of
org.eclipse.tptp.platform.log.views.internal.views.LogViewer . After doing
that however, the first line in the class, which looks like:
package org.eclipse.tests.verifcation.hooks;
now reports this error:
The type
org.eclipse.ui.views.properties.tabbed.ITabbedPropertySheetP ageContributor
cannot be resolved. It is indirectly referenced from required .class files
QuickFix tells me I should do something with the test plug-in's BuildPath
property, but now WHAT to do. Can anyone offer some suggestions at how to
fix this? It's probably pretty obvious to an experienced Eclipse/Java user,
but I'm neither of those <g>.
ddk
Re: Problem with verification hooks [message #91900 is a reply to message #91886] |
Mon, 29 January 2007 21:54 |
Liz Dancy Messages: 77 Registered: July 2009 |
Member |
You are correct, there are additional dependencies that need to be added to
the manifest file of the plug-in containing the test suite. Refer to step
six of the 'Inserting a Verification Hook' section and in addition to the
plug-ins listed there, you will need to add:
org.eclipse.ui.views.properties.tabbed and
org.eclipse.hyades.trace.ui
Next, save the manifest file and save your verification hook file and you
should see those errors disappear.
I will open a defect to get the documentation updated right away.
Sincerely,
Liz Dancy
"Daniel" <dkurtz@nospam_olenick.com> wrote in message
news:epld7m$6mq$1@utils.eclipse.org...
> of the generated VerificationClass.java, I had a number of "cannot resolve
> to type" errors on the LogViewer and related classes, which I fixed by
> letting Quick Fix add an import of
> The type
> user, but I'm neither of those <g>.
> ddk
Re: Problem with verification hooks [message #91915 is a reply to message #91886] |
Mon, 29 January 2007 23:00 |
OK, I figured out how to get around the earlier problem. Needed to add a
number of import statements, to wit:
import org.eclipse.hyades.models.cbe.CBECommonBaseEvent;
import
org.eclipse.tptp.platform.log.views.internal.views.LogConten tProvider;
import org.eclipse.tptp.platform.log.views.internal.views.LogViewer ;
And a couple of plug-ins and libraries to the manifest, beyond what the
tutorial indicates, so that 'Required Plug-ins' include:
<import plugin="org.junit"/>
<import plugin="org.eclipse.tptp.test.auto.gui"/>
<import plugin="org.eclipse.tptp.platform.log.views"/>
<import plugin="org.eclipse.tptp.platform.models"/>
<import plugin="org.eclipse.ui.views.properties.tabbed"/>
<import plugin="org.eclipse.hyades.trace.ui"/>
And 'Imported Packages':
org.eclipse.hyades.test.common.junit
Those changes, collectively, eliminated the errors from the code editor
view. However, when playing the test case back essentially the same kind of
errors are STILL occurring at runtime. The stack trace for a run reports:
java.lang.Error: Unresolved compilation problems:
LogViewer cannot be resolved to a type
LogContentProvider cannot be resolved to a type
CBECommonBaseEvent cannot be resolved to a type
at
org.eclipse.tests.verifcation.hooks.VerificationClass.verify Import(VerificationClass.java:47)
at
org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIVerifi cationHook.runTest(AutoGUIVerificationHook.java:97)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at
org.eclipse.hyades.test.common.junit.HyadesTestCase.run(Hyad esTestCase.java:173)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at
org.eclipse.hyades.test.common.junit.HyadesTestSuite.runTest (HyadesTestSuite.java:431)
at junit.framework.TestSuite.run(TestSuite.java:203)
at
org.eclipse.hyades.test.common.junit.HyadesTestSuite.doRun(H yadesTestSuite.java:399)
at
org.eclipse.hyades.test.common.junit.HyadesTestSuite.run(Hya desTestSuite.java:312)
at
org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIRunner .runVerificaitonHook(AutoGUIRunner.java:1197)
at
org.eclipse.tptp.test.auto.gui.internal.commands.Verificatio nCommand.playback(VerificationCommand.java:268)
at
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell$4.run(MacroCommandShell.java:1160)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Anybody?
> The type
> ddk
Re: Problem with verification hooks [message #91928 is a reply to message #91900] |
Tue, 30 January 2007 15:47 |
Hi Liz. Thanks for the reply. As I indicated in my reply to my own message,
I figured out which additional plug-ins etc. to add to the MFT file, however
I still get a pile of similar 'type' errors at compile/runtime. I'm thinking
possibly a buildpath issue?
BTW, "org.eclipse.tests.verifcation.hooks" is not a typo my part. The
generated verification objects are indeed named "verifcation".
"Liz Dancy" <lizdancy@ca.ibm.com> wrote in message
news:eplqg4$v8c$1@utils.eclipse.org...
> to the manifest file of the plug-in containing the test suite. Refer to
> step six of the 'Inserting a Verification Hook' section and in addition to
> the plug-ins listed there, you will need to add:
> Sincerely,
> Liz Dancy
>> resolve to type" errors on the LogViewer and related classes, which I
>> fixed by letting Quick Fix add an import of
>> The type
>> files
>> ddk
Re: Problem with verification hooks [message #91956 is a reply to message #91915] |
Tue, 30 January 2007 17:10 |
Member |
------=_NextPart_000_0044_01C74467.92D1ED20
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Daniel,
I have updated the online user guide to include all of the required =
dependencies as well as an example without the LogContentProvider as =
this seemed to be causing a conflict in the verification class.
Please retry with the updated example in the user guide: =
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-3-=
0.html. =20
Let me know if this solves the problems you are seeing.
Sincerely,
Liz Dancy
"Daniel" <dkurtz@nospam_olenick.com> wrote in message =
news:eplu8t$5a1$1@utils.eclipse.org...
> OK, I figured out how to get around the earlier problem. Needed to add =
a=20
>=20
>=20
> import=20
>=20
>=20
>=20
>=20
> And a couple of plug-ins and libraries to the manifest, beyond what =
the=20
>=20
> <import plugin=3D"org.junit"/>
> <import plugin=3D"org.eclipse.tptp.test.auto.gui"/>
> <import plugin=3D"org.eclipse.tptp.platform.log.views"/>
> <import plugin=3D"org.eclipse.tptp.platform.models"/>
> <import plugin=3D"org.eclipse.ui.views.properties.tabbed"/>
> <import plugin=3D"org.eclipse.hyades.trace.ui"/>
>=20
>=20
>=20
>=20
>=20
>=20
> Those changes, collectively, eliminated the errors from the code =
editor=20
> view. However, when playing the test case back essentially the same =
kind of=20
> errors are STILL occurring at runtime. The stack trace for a run =
reports:
>=20
>=20
> at=20
org.eclipse.tests.verifcation.hooks.VerificationClass.verify Import(Verifi=
> at=20
org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIVerifi cationHook.ru=
> at=20
org.eclipse.hyades.test.common.junit.HyadesTestCase.run(Hyad esTestCase.ja=
va:173)
> at=20
org.eclipse.hyades.test.common.junit.HyadesTestSuite.runTest (HyadesTestSu=
ite.java:431)
> at=20
org.eclipse.hyades.test.common.junit.HyadesTestSuite.doRun(H yadesTestSuit=
e.java:399)
> at=20
org.eclipse.hyades.test.common.junit.HyadesTestSuite.run(Hya desTestSuite.=
java:312)
> at=20
org.eclipse.tptp.test.auto.gui.internal.runner.AutoGUIRunner .runVerificai=
> at=20
org.eclipse.tptp.test.auto.gui.internal.commands.Verificatio nCommand.play=
> at=20
org.eclipse.tptp.test.auto.gui.internal.commands.MacroComman dShell$4.run(=
> at=20
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:1=
23)
> at=20
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:41=
9)
> at =
> at =
> at=20
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivat=
or.java:78)
> at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplicati=
> at=20
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Eclips=
> at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:4=
00)
> at=20
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
77)
>=20
> Anybody?
>=20
> "Daniel" <dkurtz@nospam_olenick.com> wrote in message=20
>> So, I'm following the tutorials in "Introduction to Using TPTP's =
Autmated=20
>> GUI Recorder" and am at the section on creating verification hooks. =
I've=20
>> followed all the steps. After adding the code to the VerifyImport =
method=20
>> of the generated VerificationClass.java, I had a number of "cannot =
resolve=20
>> to type" errors on the LogViewer and related classes, which I fixed =
by=20
>> letting Quick Fix add an import of=20
>> org.eclipse.tptp.platform.log.views.internal.views.LogViewer . After =
doing=20
>> The type=20
org.eclipse.ui.views.properties.tabbed.ITabbedPropertySheetP ageContributo=
r=20
>> cannot be resolved. It is indirectly referenced from required .class =
files
>> QuickFix tells me I should do something with the test plug-in's =
BuildPath=20
>> property, but now WHAT to do. Can anyone offer some suggestions at =
how to=20
>> fix this? It's probably pretty obvious to an experienced Eclipse/Java =
>> ddk
>>=20
>=20
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.3020" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hi Daniel,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I have updated the=20
dependencies as=20
well as an example without the LogContentProvider as this seemed to =
be=20
causing a conflict in the verification class.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Please retry with the updated =
example in=20
the user guide: </FONT><A=20
href=3D" http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-=
GUI-4-3-0.html"><FONT=20
face=3DArial=20
size=3D2> http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto=
-GUI-4-3-0.html</FONT></A><FONT=20
face=3DArial size=3D2>. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Let me know if this solves the problems =
you are=20
seeing.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Sincerely,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Liz Dancy</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Daniel" <</FONT><A=20
href=3D"mailto:dkurtz@nospam_olenick.com"><FONT face=3DArial=20
size=3D2>dkurtz@nospam_olenick.com</FONT></A><FONT face=3DArial =
size=3D2>> wrote in=20
message </FONT><A href=3D"news:eplu8t$5a1$1@utils.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:eplu8t$5a1$1@utils.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> OK, I figured =
out how to get=20
around the earlier problem. Needed to add a <BR>> number of import=20
statements, to wit:<BR>> <BR>> import=20
org.eclipse.hyades.models.cbe.CBECommonBaseEvent;<BR>> <BR>> =
import=20
<BR>>=20
org.eclipse.tptp.platform.log.views.internal.views.LogConten tProvider; <BR=
>>=20
<BR>> import=20
org.eclipse.tptp.platform.log.views.internal.views.LogViewer ; <BR>> =
<BR>>=20
<BR>> <BR>> And a couple of plug-ins and libraries to the =
manifest, beyond=20
what the <BR>> tutorial indicates, so that 'Required Plug-ins'=20
include:<BR>> <BR>> <import plugin=3D"org.junit"/><BR>> =
<import=20
plugin=3D"org.eclipse.tptp.test.auto.gui"/><BR>> <import=20
plugin=3D"org.eclipse.tptp.platform.log.views"/><BR >> <import=20
plugin=3D"org.eclipse.tptp.platform.models"/><BR>> <import=20
plugin=3D"org.eclipse.ui.views.properties.tabbed"/> <BR>> =
<import=20
plugin=3D"org.eclipse.hyades.trace.ui"/><BR>> <BR>> <BR>> =
And=20
'Imported Packages':<BR>> <BR>>=20
org.eclipse.hyades.test.common.junit<BR>> <BR>> <BR>> <BR>> =
Those=20
changes, collectively, eliminated the errors from the code editor =
<BR>> view.=20
However, when playing the test case back essentially the same kind of =
<BR>>=20
errors are STILL occurring at runtime. The stack trace for a run=20
reports:<BR>> <BR>> java.lang.Error: Unresolved compilation=20
problems:<BR>> LogViewer cannot be resolved to a=20
type<BR>> LogViewer cannot be resolved to a=20
type<BR>> LogContentProvider cannot be resolved to a=20
type<BR>> CBECommonBaseEvent cannot be resolved to a =
type<BR>>=20
<BR>> at <BR>>=20
cationClass.java:47)<BR>> at=20
sun.reflect.NativeMethodAccessorImpl.invoke0(Native =
Method)<BR>> at=20
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown =
Source)<BR>> at=20
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown =
Source)<BR>> at=20
java.lang.reflect.Method.invoke(Unknown Source)<BR>> at <BR>> =
nTest(AutoGUIVerificationHook.java:97)<BR>> at=20
junit.framework.TestCase.runBare(TestCase.java:127)<BR>> at=20
junit.framework.TestResult$1.protect(TestResult.java:106)<BR >> at=
=20
junit.framework.TestResult.runProtected(TestResult.java:124) <BR>> =
;at=20
junit.framework.TestResult.run(TestResult.java:109)<BR>> at=20
junit.framework.TestCase.run(TestCase.java:118)<BR>> at <BR>> =
va:173)<BR>> at=20
junit.framework.TestSuite.runTest(TestSuite.java:208)<BR>> at =
<BR>>=20
ite.java:431)<BR>> at=20
junit.framework.TestSuite.run(TestSuite.java:203)<BR>> at =
<BR>>=20
e.java:399)<BR>> at=20
<BR>>=20
java:312)<BR>> at=20
<BR>>=20
tonHook(AutoGUIRunner.java:1197)<BR>> at=20
<BR>>=20
back(VerificationCommand.java:268)<BR>> at=20
<BR>>=20
MacroCommandShell.java:1160)<BR>> at=20
org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5) <BR>>&nb=
sp;at=20
<BR>>=20
23)<BR>> at=20
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325) <BR>&g=
t; at=20
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971) <BR>>=
; at=20
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914) <BR>&g=
t; at=20
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878) <BR>> =
;at=20
<BR>>=20
9)<BR>> at=20
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149) <BR>&=
gt; at=20
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95) <BR=
>> at=20
<BR>>=20
or.java:78)<BR>> at=20
<BR>>=20
on(EclipseAppLauncher.java:92)<BR>> at=20
<BR>>=20
eAppLauncher.java:68)<BR>> at=20
<BR>>=20
00)<BR>> at=20
<BR>>=20
77)<BR>> at=20
Method)<BR>> at=20
Source)<BR>> at=20
Source)<BR>> at=20
java.lang.reflect.Method.invoke(Unknown Source)<BR>> at=20
org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 ) <BR>>&nbs=
p;at=20
org.eclipse.core.launcher.Main.basicRun(Main.java:280)<BR>> at=20
org.eclipse.core.launcher.Main.run(Main.java:977)<BR>> at=20
org.eclipse.core.launcher.Main.main(Main.java:952)<BR>> <BR>>=20
Anybody?<BR>> <BR>> "Daniel" <</FONT><A=20
message <BR>> </FONT><A =
href=3D"news:epld7m$6mq$1@utils.eclipse.org"><FONT=20
face=3DArial =
size=3D2>news:epld7m$6mq$1@utils.eclipse.org</FONT></A><FONT =
face=3DArial=20
size=3D2>...<BR>>> So, I'm following the tutorials in =
"Introduction to Using=20
TPTP's Autmated <BR>>> GUI Recorder" and am at the section on =
creating=20
verification hooks. I've <BR>>> followed all the steps. After =
adding the=20
code to the VerifyImport method <BR>>> of the generated=20
VerificationClass.java, I had a number of "cannot resolve <BR>>> =
to type"=20
errors on the LogViewer and related classes, which I fixed by =
<BR>>>=20
letting Quick Fix add an import of <BR>>>=20
doing=20
<BR>>> that however, the first line in the class, which looks=20
like:<BR>>><BR>>> package=20
org.eclipse.tests.verifcation.hooks;<BR>>><BR >>> now reports =
this=20
error:<BR>>><BR>>> The type <BR>>>=20
r=20
<BR>>> cannot be resolved. It is indirectly referenced from =
required=20
..class files<BR>>><BR>>> QuickFix tells me I should do =
something=20
with the test plug-in's BuildPath <BR>>> property, but now WHAT to =
do. Can=20
anyone offer some suggestions at how to <BR>>> fix this? It's =
probably=20
pretty obvious to an experienced Eclipse/Java <BR>>> user, but I'm =
neither=20
of those <g>.<BR>>><BR>>> ddk<BR>>> <BR>>=20
<BR>></FONT></BODY></HTML>
------=_NextPart_000_0044_01C74467.92D1ED20--
Current Time: Thu Apr 25 20:27:27 GMT 2024
Powered by FUDForum. Page generated in 0.03367 seconds
