Home » Archived » Eclipse Communications Framework (ECF) » ECF doesn't remember IM providers from one eclipse session to the next
ECF doesn't remember IM providers from one eclipse session to the next [message #787589] Tue, 31 January 2012 14:04 Go to next message
I installed ECF into eclipse 3.7.1 and added an IM provider. However whenever I restart eclipse, my provider is no longer there and I have to re-enter it again. Is Eclipse supposed to remember my providers? If not, it's kinda silly.
-m
Re: ECF doesn't remember IM providers from one eclipse session to the next [message #824563 is a reply to message #787589] Mon, 19 March 2012 16:29 Go to previous messageGo to next message
Mike M. wrote on Tue, 31 January 2012 14:04
-m
Can you describe what you mean by 'adding an IM provider'? ECF uses the term 'provider' to refer to a protocol provider implementation (e.g. xmpp, irc, etc)...and if a new provider (in this sense) is added then it certainly is remembered.
If by provider you mean 'account' (e.g. a gmail account...which uses the xmpp provider), then this should/has been remembered as well...so this is either a bug that we have not seen before, or it's something else that's going on in your own environment.
You will get faster responses if you join/post questions to the ecf-dev mailing list:
https://dev.eclipse.org/mailman/listinfo/ecf-dev
Re: ECF doesn't remember IM providers from one eclipse session to the next [message #824589 is a reply to message #824563] Mon, 19 March 2012 17:13 Go to previous messageGo to next message
What I meant is account. I go to Connect and then I choose XMPP then I type my account credentials (User/pw). I get connected to my jabber server. Then I quit eclipse and restart it and have to go through that all over again to connect. I.e. it does not reconnect automatically. This kind of thing doesn't happen in any other plugin, i.e. svn/git.
[Updated on: Mon, 19 March 2012 17:13] by Moderator
Re: ECF doesn't remember IM providers from one eclipse session to the next [message #940319 is a reply to message #824589] Thu, 11 October 2012 10:26 Go to previous messageGo to next message
Hi Mike.
You are correct...currently the IM session is not remembered across Eclipse sessions. This is a feature that has simply not been implemented. If you would like to open an enhancement request, and possibly contribute to the addition, it would be most welcome.
Scott
Re: ECF doesn't remember IM providers from one eclipse session to the next [message #998819 is a reply to message #787589] Thu, 10 January 2013 13:53 Go to previous message
Any updates on this? I am having the same issue and it's a real pain to keep setting up gchat everytime I start eclipse.
Previous Topic:Simple ECF Application doesnt work
Next Topic:ECF container does not get activated with Gemini Blueprint
Current Time: Tue Jun 24 19:45:00 EDT 2025
Powered by FUDForum. Page generated in 0.04731 seconds
