Home » Modeling » TMF (Xtext) » right place to add save actions?
right place to add save actions? [message #786926] Tue, 31 January 2012 00:23 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
I want to add a couple of save actions to my editor (to perform actions
like 'remove trailing whitespace', 'ensure file ends with a newline',
and 'replace funky whitespace characters with regular space' - to
mention a few).
What is the right approach to doing this. By default, it seems that the
IDE SaveAction ends up calling doSaveDocument(...) on
XtextDocumentProvider that is inherited from FileDocumentProvider.
Is it a good approach to override the document provider with my own,
implement doSaveDocument, and perform an update of the document using an
IUnitOfWork before passing on to the super doSaveDocument ?
Or is the right approach to save it twice? I.e. first save "as is", then
run a modification, and then trigger the save again?
Any pointers or bits of advice?
- henrik
Re: right place to add save actions? [message #787188 is a reply to message #786926] Tue, 31 January 2012 08:55 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Henrik,
there is no need to save twice. I'd go with modifying the document's
content and calling super.doSave...
Sebastian
Am 31.01.12 01:23, schrieb Henrik Lindberg:
> mention a few).
> Regards
> - henrik
Re: right place to add save actions? [message #940606 is a reply to message #787188] Thu, 11 October 2012 20:10 Go to previous messageGo to next message
Michael Steiner is currently offline Michael SteinerFriend
I want to implement the save action "Format source code" (i.e. "Format on save"). Therefore, I call the Xtext format command in a custom XtextDocumentProvider:
public class MyDslDocumentProvider extends XtextDocumentProvider {
	private static final String XTEXT_FORMAT_ACTION_COMMAND_ID = "org.eclipse.xtext.ui.FormatAction";
	protected void doSaveDocument(IProgressMonitor monitor, Object element, IDocument document, boolean overwrite)
			throws CoreException {
		// auto-format
		IHandlerService service = (IHandlerService) PlatformUI.getWorkbench().getService(IHandlerService.class);
		try {
			service.executeCommand(XTEXT_FORMAT_ACTION_COMMAND_ID, null);
		} catch (ExecutionException | NotDefinedException | NotEnabledException | NotHandledException e) {
			e.printStackTrace();
		// save
		super.doSaveDocument(monitor, element, document, overwrite);
Is this the right approach or is there a better way?
Michael
Re: right place to add save actions? [message #1412967 is a reply to message #940606] Wed, 27 August 2014 12:57 Go to previous message
Markus Duft is currently offline Markus DuftFriend
The above made my day, thanks Smile
Previous Topic:Code Formatter and comments.
Next Topic:Non-empty model in the beginning
Current Time: Tue Sep 29 01:12:42 GMT 2020
Powered by FUDForum. Page generated in 0.08703 seconds
