Home » Eclipse Projects » Equinox » Axis2 in Equinox
Axis2 in Equinox [message #91441] Sun, 01 July 2007 17:55 Go to next message
LO is currently offline LOFriend
I really want to add Web Service support to my run-time stack, preferably
with the Jetty server
Axis2 seams like the choice and I saw that Apache Muse has some OSGi bundle
for Axis2. But I really need
some advice to get going
BR
Lars
Re: Axis2 in Equinox [message #91634 is a reply to message #91441] Fri, 06 July 2007 06:55 Go to previous messageGo to next message
Karsten Panier is currently offline Karsten PanierFriend
Member
Lars schrieb:
> BR
> Lars
I am interested in this topic too. I read this tutorial:
http://www-128.ibm.com/developerworks/edu/ws-dw-ws-eclipsepl ugin.html
Now I can run webservices with axis 1.4 in tomcat with osgi and in
equinox with jetty. The disadvantage is that I have one central config
file "server-config.wsdd" to register the webservices. Another Point is
that I want to use axis2 and not axis.
I looked at the corona and ohf projects. They seems to use axis2 for
their webservices. I didn't find docs or any simple code example to
understand how that works.
Where can I find some Examples about it?
regards
karsten
Re: Axis2 in Equinox [message #91870 is a reply to message #91441] Tue, 10 July 2007 10:38 Go to previous messageGo to next message
Originally posted by: the.dev.ich-will-net.de
We managed to get Axis2 running within the Jetty http service(based on Eclipse 3.2.2) for some simple prototyping. So there might be some stuff to do, but it is working in principle. So, what do you want to know?
Jörg
Re: Axis2 in Equinox [message #91902 is a reply to message #91870] Tue, 10 July 2007 15:17 Go to previous messageGo to next message
Member
Jörg Lehmann schrieb:
> Jörg
Hi Jörg,
how managed you to get Axis2 running in equinox? I packed the necessory
jars in one bundle. Than i registered the AxisServelt as a
org.osgi.service.http.HttpService.
I am not sure if this is the right way. I also don't know how to deploy
a webservice to it.
Any hints?
Karsten
Re: Axis2 in Equinox [message #91991 is a reply to message #91902] Wed, 11 July 2007 17:52 Go to previous messageGo to next message
Hi Karsten,
I kind of remember that OHF also used osgi services to register their web services. But i think that you'll probably have to dig much more deeper into the Axis2 framework to configure & provide web services that way.
We went a little different way for our prototype. We simply used the Jetty Http Implementation and registered the AxisServlet and all other aliases (see Axis2' web.xml). Instead of stuffing all libraries into one bundle, we separated them into logical packages like axis libs, several commons libs, ...
We've got one bundle which acts as some kind of Axis2-OSGi-Wrapper which has a WebContent subfolder (with a similar stucture like the axis2 web-app), which registers the servlets and http context to the http service implementation. By putting your webservice archives to the according services folder you can make the services available to clients.
If you once got it going you can continue with more sophisticated logic: Our next step was to provide the custom webservices on a component base. I.e. we provided an extension point for custom bundles (within the wrapper bundle) to add more services by giving their *.wsdd and service.xml file. The wrapper bundle collects all bundles on start-up and generates the according aar files in it's service folder (only the configuration files are included, the implementation still resides in the original bundles and is accessible via buddy class-loading). The next step would have been to avoid the creation of the 'dummy' aar files and add / configure the services directly in code, but with stop at that point for now. If that one is done it is probably no big step to use a osgi service instead of the indirection via jetty.
A very pragmatic solution, but it helped us to get started.
Hope it helps you a just little bit..
Jörg
Re: Axis2 in Equinox [message #92054 is a reply to message #91991] Thu, 12 July 2007 16:41 Go to previous messageGo to next message
Member
Hi Jörg,
yes it helps. I have now axis2 in equinox running. It looks different to
the ohf or corona axis2 bundles but it works.
Karsten
Re: Axis2 in Equinox [message #108305 is a reply to message #92054] Wed, 16 April 2008 19:23 Go to previous message
ouertani is currently offline ouertaniFriend
Can u give us a step by step help to do Webservices in equinox.
I try many example but with no success.
thanks in advance.
Previous Topic:extendedFrameworkExports doesn't report unresolved dependencies
Next Topic:NPE in my Servlet init kills http registry service...
Current Time: Mon Dec 06 20:06:40 GMT 2021
Powered by FUDForum. Page generated in 0.02226 seconds
