Home » Archived » Visual Editor (VE) » Required CVS check-out to build VE?
Required CVS check-out to build VE? [message #91302] Mon, 16 May 2005 16:18 Go to next message
Originally posted by: no.ddress.here
Checked out ve-dev-base and even tried the ve-all set of projects from
CVS. In both cases, problems encountered with:
org.eclipse.jdt.internal.ui.dialogs.TypeSelectionDialog2
(cause: import not found)
and
org.eclipse.jdt.ui.wizards.
NewWizardMessages.NewTypeWizardPage_operationdesc
(cause: import found, but method not resolved)
and other similar errors.
Is there something different I need to do be able to build VE? A missing
support jar?
My specific need is to be able to set breakpoints in VE to analyze a
problem in my code that only shows up when VE finally executes:
org.eclipse.ve.internal.java.core.CustomizeJavaBeanAction.cu stomizerOK
Currently running
JDK1.5
Eclipse 3.1M6
EMF build I200504141117
GEF Build 3.1M6
VE-runtime-1.1M1
Gerald
Re: Required CVS check-out to build VE? [message #91316 is a reply to message #91302] Mon, 16 May 2005 16:41 Go to previous messageGo to next message
The latest code works against Eclipse M7. IT won't compile against M6
because of changes made between M6 and M7 in Eclipse.
> and
> support jar?
> Currently running
> JDK1.5
> Eclipse 3.1M6
> GEF Build 3.1M6
> VE-runtime-1.1M1
> Gerald
Rich Kulp
Re: Required CVS check-out to build VE? [message #91344 is a reply to message #91316] Mon, 16 May 2005 19:16 Go to previous message
In article <d6b0il$s9a$1@news.eclipse.org>, richkulp@us.NO_SPAM.ibm.com
says...
Got it. Compiles without error. Thanks.
Re: Required CVS check-out to build VE? [message #607778 is a reply to message #91302] Mon, 16 May 2005 16:41 Go to previous message
> and
> support jar?
> Currently running
> JDK1.5
> Eclipse 3.1M6
> GEF Build 3.1M6
> VE-runtime-1.1M1
> Gerald
Rich Kulp
Re: Required CVS check-out to build VE? [message #607780 is a reply to message #91316] Mon, 16 May 2005 19:16 Go to previous message
says...
Previous Topic:Required CVS check-out to build VE?
Next Topic:One question about SWT Applicaiton run in Linux FC2.
Current Time: Mon Jul 07 19:49:51 EDT 2025
Powered by FUDForum. Page generated in 0.04387 seconds
