Home » Eclipse Projects » EclipseLink » Composite Key Configuration using Dynamic Eclipse Link API
Composite Key Configuration using Dynamic Eclipse Link API [message #784225] Fri, 27 January 2012 08:08 Go to next message
Nabeel Ahmed is currently offline Nabeel AhmedFriend
I m try to configure a Dynamic Type which have composite primary key, but i am having a problem in its configuration.
* Configuring ProductKey
JPADynamicTypeBuilder productKeyTypeBuilder = new JPADynamicTypeBuilder(classLoader.createDynamicClass(packageName + "ProductKey"), null);
productKeyTypeBuilder.addDirectMapping("ProductID", int.class,"ProductID");
productKeyTypeBuilder.addDirectMapping("ProductName", String.class, "ProductName");
* Configuring Products
JPADynamicTypeBuilder productTypeBuilder = new JPADynamicTypeBuilder(classLoader.createDynamicClass(packageName + "Products"), null, "Products");
productTypeBuilder.addDirectMapping("QuantityPerUnit", String.class,"QuantityPerUnit");
productTypeBuilder.addDirectMapping("UnitPrice", Double.class, "UnitPrice");
productTypeBuilder.addDirectMapping("UnitsInStock", Short.class, "UnitsInStock");
productTypeBuilder.addDirectMapping("UnitsOnOrder", Short.class, "UnitsOnOrder");
productTypeBuilder.addDirectMapping("ReorderLevel", Short.class, "ReorderLevel");
productTypeBuilder.addDirectMapping("Discontinued", Boolean.class, "Discontinued");
AggregateObjectMapping aom = productTypeBuilder.addAggregateObjectMapping("ProductKey", productKeyTypeBuilder.getType(), true);
aom.setIsPrimaryKeyMapping(true);
aom.setIsReadOnly(false);
and i m getting errors in it.
am i missing anything?
any help?
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #786491 is a reply to message #784225] Mon, 30 January 2012 13:52 Go to previous messageGo to next message
I m still facing this problem, please help me in this regard
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #786498 is a reply to message #784225] Mon, 30 January 2012 13:52 Go to previous messageGo to next message
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #786579 is a reply to message #786498] Mon, 30 January 2012 15:53 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Do not set,
This is internal. Set the primary key fields using,
productTypeBuilder.setPrimaryKeyFields("field1", "field2", etc.).
James : Wiki : Book : Blog : Twitter
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #786585 is a reply to message #786498] Mon, 30 January 2012 15:53 Go to previous messageGo to next message
Do not set,
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #787076 is a reply to message #786579] Tue, 31 January 2012 05:49 Go to previous messageGo to next message
Thanks for your reply, i tried it.
packageName + "ProductKey"), null, "Products");
packageName + "Products"), null,"Products");
productTypeBuilder.setPrimaryKeyFields("ProductID", "ProductName");
productTypeBuilder.addAggregateObjectMapping("productKey", productKeyTypeBuilder.getType(), true);
productTypeBuilder.addDirectMapping("QuantityPerUnit", String.class, "QuantityPerUnit");
when i run the code on JBoss AS 7.1.0 with SQL Server 2010, Now i got this error.
is it a bug in EclipseLink 2.3.2?
if not, then what is missing/wrong here?
Exception [EclipseLink-0] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: An internal error occurred accessing the primary key object [202].
Internal Exception: java.lang.NoSuchFieldException: ProductID
Descriptor: RelationalDescriptor(com.lgc.dsl.model.Products --> [DatabaseTable(Products)])
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #787077 is a reply to message #786579] Tue, 31 January 2012 05:50 Go to previous messageGo to next message
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #787463 is a reply to message #787077] Tue, 31 January 2012 16:02 Go to previous messageGo to next message
Any help regarding this issue?
I still didn't able to solve it.
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #787467 is a reply to message #787077] Tue, 31 January 2012 16:02 Go to previous messageGo to next message
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #788759 is a reply to message #787463] Thu, 02 February 2012 07:16 Go to previous messageGo to next message
I think there is a bug in org.eclipse.persistence.internal.jpa.CMP3Policy.java
Or may be i am missing something?
Please do help me in this regard, its been a week now that i m troubleshooting this problem.
Thank you
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #789053 is a reply to message #788759] Thu, 02 February 2012 14:52 Go to previous messageGo to next message
The same error i got with orm.xml.
<entity-mappings version="2.1"
xmlns="http://www.eclipse.org/eclipselink/xsds/persistence/orm"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<package>example.jpa.dynamic.model</package>
<entity class="Products" access="VIRTUAL">
<table name="Products"></table>
<attributes>
<embedded-id name="productKey" attribute-type="ProductKey"/>
<basic name="UnitPrice" attribute-type="java.lang.Double" />
<basic name="Discontinued" attribute-type="java.lang.Boolean" />
</attributes>
</entity>
<embeddable class="ProductKey" access="VIRTUAL">
<attributes>
<basic name="ProductID" attribute-type="java.lang.Integer" />
<basic name="ProductName" attribute-type="java.lang.String" />
</attributes>
</embeddable>
</entity-mappings>
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #789135 is a reply to message #789053] Thu, 02 February 2012 16:40 Go to previous message
I think the issue is you are trying to use an embedded id, with a class that does not exist. Don't do this, just define each id (no different than if it was a singleton pk).
The full stack trace would help diagnose the issue with using an embedded id, my guess is there is an issue there that you may wish to log bug for.
You should be able to use a List or Object[] of the id values if using find.
Otherwise you could try defining a real class for the id.
Re: Composite Key Configuration using Dynamic Eclipse Link API [message #789136 is a reply to message #789053] Thu, 02 February 2012 16:40 Go to previous message
Previous Topic:NoSQL
Next Topic:composite key order
Current Time: Wed Feb 26 20:26:53 GMT 2020
Powered by FUDForum. Page generated in 0.03491 seconds
