Error While Creating Data Source [message #783953] |
Thu, 26 January 2012 20:26 |
Rob LaPrelle Messages: 2 Registered: January 2012 |
When I try to create a JDBC Data Source (right click 'Data Sources', select 'New Data Source', Highlight 'JDBC Data Source', Enter name, click 'Next >') I get the following error and am unable to create the data source. I am entering this info into bugzilla, but is there a workaround? My session info is bellow the error.
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.rangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.JdbcToolKit.getJdbcDriversFromODADir(JdbcToolKit.java:109)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper.createCustomControl(JDBCSelectionPageHelper.java:140)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionWizardPage.createPageCustomControl(JDBCSelectionWizardPage.java:54)
at org.eclipse.datatools.connectivity.oda.design.ui.wizards.DataSourceWizardPage.createCustomControl(DataSourceWizardPage.java:131)
at org.eclipse.datatools.connectivity.ui.wizards.ConnectionProfileDetailsPage.createControl(ConnectionProfileDetailsPage.java:105)
at org.eclipse.datatools.connectivity.oda.design.internal.ui.DataSourceWizardPageCore.createControl(DataSourceWizardPageCore.java:226)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
at org.eclipse.datatools.connectivity.ui.wizards.NewConnectionProfileWizard.createPageControls(NewConnectionProfileWizard.java:309)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1183)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1242)
at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1239)
at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1228)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1226)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:915)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:428)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.data.ui.actions.NewDataSourceAction.run(NewDataSourceAction.java:126)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
eclipse.buildId=M20110909-1335
java.version=1.7.0_01
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product -clean
Re: Error While Creating Data Source [message #784508 is a reply to message #783953] |
Fri, 27 January 2012 16:21 |
Which version of the designer did you download?
Jason
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
FUDForum. Page generated in 0.03537 seconds
