Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Latest build Teneo, backward compatibility
Re: Latest build Teneo, backward compatibility [message #90677 is a reply to message #90595] |
Thu, 19 July 2007 10:38 |
Originally posted by: benjamin.cabeNOSPAMM.anyware-tech.DOTcom
Hi Martin,
TeneoSQLNameStrategy looks just great ; my columns now have very
understandable names !..
However, I just opened the bug #197110, tell me if you think it's worth
trying to make this enhancement ....
It could also be interesting to change the way the loop through "aeiou"
is done to not remove all A's then all E's etc. but, instead, every
vowel one after another ...
Benjamin.
Martin Taal a écrit :
> This new build of Teneo solves a number of issues (see the release notes).
> One change is important for backward compatability: the way Teneo
> truncates long sql names has been improved. This change means that sql
> (table and column) generated by Teneo can differ from previous versions.
> This difference only applies in case the maximum sql name length option
> was set and table or column names are too long. In this case please
> check out this bugzilla for hints on how to retain backward compatability:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=196951
> Related to this a new default naming strategy is now used, see here:
> http://www.elver.org/hibernate/extensions.html#TeneoSQLNameS trategy+%28default%29
Re: Latest build Teneo, backward compatibility [message #90690 is a reply to message #90677] |
Thu, 19 July 2007 10:55 |
Hi Benjamin,
Yes your bugzilla is valid. I agree that not-removing the first vowel makes it more readable (I
found that approach also on the internet at oracle).
With the other remark, do you mean that instead of this loop:
for (String vowel : vowels) {
while (not yet finished) {
remove one occurence of vowel
if (finished) goaway
it should do this:
If you mean this then I think that either approach is valid. Just let me know what are the arguments
for the other approach.
There should be some literature on the internet which says what gives most readable results (I only
found removing vowels in general but no discussion on other strategies, like first remove u then o
etc.).
Btw, it is easy to plugin your own naming strategy, so you can try different approaches yourselve.
You just need to do this before you initialize the datastore:
dataStore.getExtensionManager().registerExtension(SQLNameStr ategy.class.getName(),
MyGreatNamingStrategy.class.getName()));
(were MyGreatNamingStrategy extends the TeneoSQLNameStrategy and overrides the trunc method)
gr. Martin
Benjamin CABE wrote:
> Hi Martin,
> Regards,
> Benjamin.
>> notes).
>> versions. This difference only applies in case the maximum sql name
>> length option was set and table or column names are too long. In this
>> case please check out this bugzilla for hints on how to retain
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Latest build Teneo, backward compatibility [message #90793 is a reply to message #90690] |
Thu, 19 July 2007 12:44 |
> makes it more readable (I found that approach also on the internet at
> oracle).
OK, I'll post the (trivial ;) ) fix, then.
> it should do this:
> know what are the arguments for the other approach.
Yes it is what I meant. In fact, there's no particular argument; all the
more I didn't noticed you've used a specific order for the vowels
("uoaei") according to their importance I presume. It might be enough
for the "generic" TeneoSQLNameStrategy.
> different approaches yourselve. You just need to do this before you
Yes I noticed that already. Simply great :)
Just a last point : don't you think MAXIMUM_SQL_NAME_LENGTH should have
a lower limit (1 would be the bare minimum, even if it's pretty hard to
imagine someone setting MAXIMUM_SQL_NAME_LENGTH to 0 or 1 ;-) )
Benjamin.
Re: Latest build Teneo, backward compatibility [message #91080 is a reply to message #90793] |
Fri, 20 July 2007 09:45 |
I have added a check on max sql name length, if it is zero an exception is thrown as the mapping
file will get empty column/table names.
If it is lower than 4 a warning is logged.
gr. Martin
>> oracle).
>> it should do this:
>> me know what are the arguments for the other approach.
> Regards,
> Benjamin.
The Netherlands
Re: Latest build Teneo, backward compatibility [message #608805 is a reply to message #90595] |
Hi Martin,
Benjamin.
Re: Latest build Teneo, backward compatibility [message #608806 is a reply to message #90677] |
Hi Benjamin,
it should do this:
etc.).
gr. Martin
> Hi Martin,
> Regards,
> Benjamin.
>> notes).
The Netherlands
Re: Latest build Teneo, backward compatibility [message #608813 is a reply to message #90690] |
> oracle).
> it should do this:
Benjamin.
Re: Latest build Teneo, backward compatibility [message #608832 is a reply to message #90793] |
gr. Martin
>> oracle).
>> it should do this:
> Regards,
> Benjamin.
The Netherlands
Current Time: Fri Apr 19 22:52:18 GMT 2024
Powered by FUDForum. Page generated in 0.04176 seconds
