Re: creating javascript vector from dataSetRow [message #782407 is a reply to message #781989] |
Mon, 23 January 2012 16:55 |
Do you want to do this in the server side script of BIRT or are you
wanting this to be a client side available array? If it is all server
side you can add a table tied to the dataset and load up a js array in
the table rows' oncreate or on the expression of a given item in the
table. Next you can hide the table with visibility so it does not show
in the report. Have a look at the attached example.
Jason
On 1/22/2012 6:12 PM, Christoph Kiehn wrote:
> I just started using BIRT.
> I'm wondering about an easy way to construct a javascript vector (or
> even a matrix) from dataSetRow elements.
> I'd like to do some math on this vectors...
> Thanks C
Attachment: jsarray.zip
(Size: 2.66KB, Downloaded 196 times)
Re: creating javascript vector from dataSetRow [message #782412 is a reply to message #781989] |
Jason
> Thanks C
(Size: 2.66KB, Downloaded 177 times)
Re: creating javascript vector from dataSetRow [message #782419 is a reply to message #781989] |
Jason
> Thanks C
(Size: 2.66KB, Downloaded 222 times)
FUDForum. Page generated in 0.02848 seconds
