Re: BIRT 3.7 Report with Multiple Columns [message #782400 is a reply to message #781578] |
Mon, 23 January 2012 16:46 |
Shane,
If you mean like a newspaper flow, it is not supported yet, but you can
just put a two or three column grid in and then put tables, charts, etc
into each of the columns. You can also add a computed column to tables
and filter the list of rows displayed in a table. Take a look at the
attached example.
Jason
On 1/21/2012 12:45 PM, Shane Allred wrote:
> Does BIRT 3.7 support multiple column reports. I've tried setting this
> up on the Master Page but no matter what I try the report is always
> rendered with a single column. I've read this should be supported now,
> but I've found no concrete examples or tutorials on how to make this work.
> I am trying to set "Master Page" > "Advanced" > "Columns"
Re: BIRT 3.7 Report with Multiple Columns [message #783035 is a reply to message #782897] |
Tue, 24 January 2012 23:28 |
Shane
Currently this is not implemented in commercial or open source. It is
in bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=133218
Can you please vote on this?
Can you give some more detail on how you want it to flow and maybe with
some scripting we can provide a work around.
Jason
On 1/24/2012 12:00 PM, Shane Allred wrote:
> Thanks Jason. Yes, I am trying to have content flow into columns similar
> to a newspaper layout.
> Do you know if it is on the roadmap at all? I can use computed columns
> and filters for some reports, but I can't think of a good way to have
> the report flow into columns the way I'd like.
> Does the commercial product support this? I'm confused because there is
> information online that makes it seem like this feature has been
> implemented.
> For example:
> eclipse.org/birt/ref/rom/elements/GraphicMasterPage.html
> Thanks
FUDForum. Page generated in 0.02863 seconds
