Home » Eclipse Projects » Virgo » org.eclipse.virgo.kernel.deployer bundle is not started correctly
org.eclipse.virgo.kernel.deployer bundle is not started correctly [message #781068] |
Fri, 20 January 2012 10:23 |
Anton Kolmakov Messages: 14 Registered: January 2012 |
Hi, I'm trying to create own application deployer using deployer MBean. But after I'd added dependency on org.eclipse.virgo.kernel.deployer bundle, the server's failed to create an application context of this bundle:
[2012-01-20 12:04:16.390] WARN service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&kernelConfig' in bundle 'org.eclipse.virgo.kernel.deployer' version '3.0.2.RELEASE' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.core.KernelConfig)'.
[2012-01-20 12:04:16.392] WARN service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&bundleStarter' in bundle 'org.eclipse.virgo.kernel.deployer' version '3.0.2.RELEASE' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.core.BundleStarter)'.
[2012-01-20 12:05:11.391] WARN Timer-1 o.s.o.e.i.d.startup.DependencyWaiterApplicationContextExecutor Timeout occurred before finding service dependencies for [OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml)]
[2012-01-20 12:05:11.393] INFO Timer-1 o.s.beans.factory.support.DefaultListableBeanFactory Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@5ba5d: defining beans [moduleContextEventPublisher,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#0,applicationDeployer,recoveryLog,deploymentListener,artifactStorageFactory,syntheticContextCreatingTransformer,scopingTransformer,bundleManifestVersionUpgrader,planResolver,importExpandingTransformer,bundleDeploymentProperties,userInstalledTaggingTransformer,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#1,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#2,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#3,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#4,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#5,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#6,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#7,recoveryMonitorService,recoveryMonitor,recoveryAgent,mainPipeline,refreshSubpipeline,pipelinedApplicationDeployer,stateCleanupListener,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#8,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#9,uriNormaliser,plumber,pipelineFactory,installArtifactTreeInclosure,installEnvironmentFactory,runtimeArtifactModel,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#10,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#11,loggingListener,kernelConfig,deployerConfig,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#12,applicationDeploymentEventNotifier,deploymentListeners,packageAdminUtil,scopeFactory,scopeServiceRepository,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#13,artifactBridges#org.springframework.osgi.service.importer.support.OsgiServiceCollectionProxyFactoryBean#0,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#14,artifactIdentityDeterminer,refreshHandler,bundleInstallArtifactTreeFactory,userBundleContext,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#15,configInstallArtifactTreeFactory,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#16,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#17,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#18,hotDeployer,hotDeployerService,configAdmin,eventLogger,dumpGenerator,packageAdmin,repository,shutdown,tracingService,workArea,osgiFramework,quasiFrameworkFactory,eventAdmin,bundleStarter,importExpander,org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean#19,org.eclipse.virgo.kernel.management.ManagementExporter#0,org.eclipse.virgo.kernel.management.ManagementExporter#1,org.eclipse.virgo.kernel.serviceability.dump.DumpCoordinator#0]; root of factory hierarchy
[2012-01-20 12:05:11.396] ERROR Timer-1 o.s.o.e.i.d.startup.DependencyWaiterApplicationContextExecutor Unable to create application context for [org.eclipse.virgo.kernel.deployer], unsatisfied dependencies: Dependency on [(objectClass=org.eclipse.virgo.kernel.core.KernelConfig)] (from bean [&kernelConfig]), Dependency on [(objectClass=org.eclipse.virgo.kernel.core.BundleStarter)] (from bean [&bundleStarter]) org.springframework.context.ApplicationContextException: Application context initialization for 'org.eclipse.virgo.kernel.deployer' has timed out
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
[2012-01-20 12:05:11.397] INFO Timer-1 .a.d.i.BlueprintEventPostingOsgiBundleApplicationContextListener Sending event to topic 'org/osgi/service/blueprint/container/FAILURE' with properties '{bundle.version=3.0.2.RELEASE, bundle=org.eclipse.virgo.kernel.deployer_3.0.2.RELEASE [119], bundle.symbolicName=org.eclipse.virgo.kernel.deployer, exception=org.springframework.context.ApplicationContextException: Application context initialization for 'org.eclipse.virgo.kernel.deployer' has timed out, type=5, timestamp=1327053911396, bundle.id=119}'
[2012-01-20 12:05:11.398] INFO Timer-1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/FAILURE]'
[2012-01-20 12:05:11.398] ERROR Timer-1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Recording application context construction failure 'org.springframework.context.ApplicationContextException: Application context initialization for 'org.eclipse.virgo.kernel.deployer' has timed out' for bundle 'org.eclipse.virgo.kernel.deployer_3.0.2.RELEASE [119]'
[2012-01-20 12:05:11.403] ERROR Timer-1 org.eclipse.virgo.medic.eventlog.default AG0000E Application context creation failure for bundle 'org.eclipse.virgo.kernel.deployer' version '3.0.2.RELEASE'. org.springframework.context.ApplicationContextException: Application context initialization for 'org.eclipse.virgo.kernel.deployer' has timed out
[2012-01-20 12:05:11.404] ERROR Timer-1 o.s.osgi.extender.internal.activator.ContextLoaderListener Application context refresh failed (OsgiBundleXmlApplicationContext(bundle=org.eclipse.virgo.kernel.deployer, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.context.ApplicationContextException: Application context initialization for 'org.eclipse.virgo.kernel.deployer' has timed out
Any ideas what could be wrong?
Current Time: Tue Apr 23 06:08:10 GMT 2024
Powered by FUDForum. Page generated in 0.03601 seconds
