Home » Eclipse Projects » GEF » [zest2.0] Status of zooming in zest 2.0
[zest2.0] Status of zooming in zest 2.0 [message #780817] Thu, 19 January 2012 13:57 Go to next message
Erdal Karaca is currently offline Erdal KaracaFriend
What is the current status of zooming in a zest based GraphViewer 2.0?
Re: [zest2.0] Status of zooming in zest 2.0 [message #780930 is a reply to message #780817] Fri, 20 January 2012 00:00 Go to previous messageGo to next message
Fabian Steeg is currently offline Fabian SteegFriend
Member
I haven't used zooming myself, but I'm not aware of any differences in that area between Zest 1.x and 2.0. A general sample can be found in this tutorial: http://www.vogella.de/articles/EclipseZest/article.html
Re: [zest2.0] Status of zooming in zest 2.0 [message #781070 is a reply to message #780930] Fri, 20 January 2012 10:34 Go to previous messageGo to next message
Connections with custom anchors are not rendered properly when zomming (in/out).
I am customizing connections in the selfStyleConnection method.
Re: [zest2.0] Status of zooming in zest 2.0 [message #781072 is a reply to message #781070] Fri, 20 January 2012 11:06 Go to previous messageGo to next message
I have attached two screenshots: one without zooming (zoom level set to 100%) and one with zoom level set to 150%...
  • Attachment: nozoom.png
    (Size: 5.89KB, Downloaded 253 times)
  • Attachment: withzoom.png
    (Size: 8.38KB, Downloaded 255 times)
Re: [zest2.0] Status of zooming in zest 2.0 [message #781081 is a reply to message #781072] Fri, 20 January 2012 12:59 Go to previous messageGo to next message
Member
That doesn't look good - could you file a bug with the code causing the issue?
Re: [zest2.0] Status of zooming in zest 2.0 [message #782125 is a reply to message #781081] Mon, 23 January 2012 08:11 Go to previous message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=369357
Previous Topic:ZEST: Disable manual movement of some, but not all nodes in a graph?
Next Topic:Retrieve point of selection
Current Time: Tue Dec 07 13:23:51 GMT 2021
Powered by FUDForum. Page generated in 0.03609 seconds
