Home » Eclipse Projects » EclipseLink » Shared cache on multi base using same classes
Shared cache on multi base using same classes [message #780558] Wed, 18 January 2012 15:53 Go to next message
Robin CAMUS is currently offline Robin CAMUSFriend
I'm using eclipselink to access multiple bases using the same tables and i want to know if i can simply use a persistence.xml like this :
<persistence version="1.0" ... (cannot use links :X)>
<persistence-unit name="DATA_M" transaction-type="JTA">
    <provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
    <jta-data-source>jdbc/DATA_M</jta-data-source>
          <class>onp.modele.adli.ListeDiffusion</class>
          <class>onp.modele.commun.Agent</class>
          <class>onp.modele.commun.JourFerie</class>
          <class>onp.modele.adse.SecteurRegle</class>
    <properties>
      <property name="eclipselink.weaving.internal" value="false"/>
    </properties>
  </persistence-unit>
  <persistence-unit name="DATA_X" transaction-type="JTA">
    <properties>
    </properties>
  </persistence-unit>
  ... (for 20 different persistence units)
Do eclipselink use different cache for each datasource?
Or will i ll be experiencing some cache issue (2 onp.modele.commun.Agent can have the same id key but different values if they re not in the same base).
Or do i need to specify additionals properties so i can use it like this.
Thx in advance.
Other stuff :
Using
weblogic 10.3.4
eclipselink 2.1.2
Re: Shared cache on multi base using same classes [message #780853 is a reply to message #780558] Thu, 19 January 2012 16:28 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Each persistence unit will have its own shared cache.
Nothing will be shared between these different persistence units.
James : Wiki : Book : Blog : Twitter
Re: Shared cache on multi base using same classes [message #782183 is a reply to message #780853] Mon, 23 January 2012 10:09 Go to previous message
Thx for the quick answer
Re: Shared cache on multi base using same classes [message #782187 is a reply to message #780853] Mon, 23 January 2012 10:09 Go to previous message
Previous Topic:Error generating static Data Objects from XSD
Next Topic:Documentation of nonstandard features
Current Time: Mon Mar 30 00:04:23 GMT 2020
Powered by FUDForum. Page generated in 0.01913 seconds
