Home » Archived » Eclipse Communications Framework (ECF) » ContainerConnectException / Connection refused using R-OSGi
ContainerConnectException / Connection refused using R-OSGi [message #779861] |
Mon, 16 January 2012 17:35 |
Pablo Mising name Messages: 24 Registered: July 2010 |
Hi all.
I am testing the performance of the providers available in ECF. I don't have problems using the Zeroconf/Generic mechanisms. However, using R-OSGi I receive the following exception in the Consumer side:
!ENTRY org.eclipse.ecf.osgi.services.remoteserviceadmin 4 0 2012-01-16 18:04:54.905
!MESSAGE org.eclipse.core.runtime.Status[plugin=org.eclipse.ecf.osgi.services.remoteserviceadmin;code=4;message=org.eclipse.ecf.osgi.services.remoteserviceadmin.RemoteServiceAdmin:importService:selectRemoteServiceReference returned null for rsRefs=[],targetID=r-osgi://localhost:3999,idFilter=[Lorg.eclipse.ecf.core.identity.ID;@495b0e2c,interfaces=[es.ugr.osgiliath.evolutionary.elements.FitnessCalculator],rsFilter=(&(ecf.rsvc.id=71)),rsContainerID=r-osgi://evorq:9282;severity4;exception=org.eclipse.ecf.core.ContainerConnectException: ;children=[]]
!STACK 0
at org.eclipse.ecf.internal.provider.r_osgi.R_OSGiRemoteServiceContainer.connect(R_OSGiRemoteServiceContainer.java:517)
at org.eclipse.ecf.internal.provider.r_osgi.R_OSGiRemoteServiceContainer.getRemoteServiceReferences(R_OSGiRemoteServiceContainer.java:240)
at org.eclipse.ecf.internal.provider.r_osgi.R_OSGiRemoteServiceContainer.getRemoteServiceReferences(R_OSGiRemoteServiceContainer.java:206)
at org.eclipse.ecf.osgi.services.remoteserviceadmin.RemoteServiceAdmin.importService(RemoteServiceAdmin.java:1965)
at org.eclipse.ecf.osgi.services.remoteserviceadmin.RemoteServiceAdmin.importService(RemoteServiceAdmin.java:356)
at org.eclipse.ecf.osgi.services.remoteserviceadmin.AbstractTopologyManager.handleEndpointAdded(AbstractTopologyManager.java:225)
at org.eclipse.ecf.internal.osgi.services.distribution.BasicTopologyManager.endpointAdded(BasicTopologyManager.java:133)
at org.eclipse.ecf.osgi.services.remoteserviceadmin.EndpointDescriptionLocator$1.dispatchEvent(EndpointDescriptionLocator.java:154)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:327)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:193)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:180)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:384)
at java.net.Socket.connect(Socket.java:546)
at java.net.Socket.connect(Socket.java:495)
at java.net.Socket.<init>(Socket.java:392)
at java.net.Socket.<init>(Socket.java:206)
at ch.ethz.iks.r_osgi.impl.TCPChannelFactory$TCPChannel.<init>(TCPChannelFactory.java:171)
at ch.ethz.iks.r_osgi.impl.TCPChannelFactory.getConnection(TCPChannelFactory.java:76)
at ch.ethz.iks.r_osgi.impl.ChannelEndpointImpl.<init>(ChannelEndpointImpl.java:212)
at ch.ethz.iks.r_osgi.impl.RemoteOSGiServiceImpl.connect(RemoteOSGiServiceImpl.java:686)
at org.eclipse.ecf.internal.provider.r_osgi.R_OSGiRemoteServiceContainer.doConnect(R_OSGiRemoteServiceContainer.java:525)
at org.eclipse.ecf.internal.provider.r_osgi.R_OSGiRemoteServiceContainer.connect(R_OSGiRemoteServiceContainer.java:506)
... 9 more
The bundles available in HOST are:
id State Bundle
0 ACTIVE org.eclipse.osgi_3.7.1.R37x_v20110808-1106
1 ACTIVE org.eclipse.equinox.concurrent_1.0.200.v20110502
2 ACTIVE org.objectweb.asm_3.3.1.v201105211655
3 ACTIVE org.eclipse.core.contenttype_3.4.100.v20110423-0524
4 ACTIVE ch.ethz.iks.r_osgi.remote_1.0.0.RC4_v20111230-0120
5 ACTIVE org.eclipse.ecf_3.1.300.v20110531-2218
6 ACTIVE org.eclipse.ecf.identity_3.1.100.v20110531-2218
7 ACTIVE OsgiliathFunctionsProblems_1.0.0.qualifier
8 ACTIVE org.eclipse.ecf.discovery_4.0.0.v20111230-0120
9 ACTIVE org.eclipse.ecf.provider.jmdns_4.1.0.v20111230-0120
10 ACTIVE org.eclipse.equinox.preferences_3.4.1.R37x_v20110725
11 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0.v20111230-0120
12 ACTIVE es.ugr.osgiliath_1.0.0
13 ACTIVE org.eclipse.ecf.provider_4.2.100.v20111230-0120
14 ACTIVE org.eclipse.equinox.ds_1.3.1.R37x_v20110701
15 ACTIVE org.eclipse.ecf.remoteservice_6.0.200.v20111230-0120
16 ACTIVE org.eclipse.equinox.util_1.0.300.v20110502
17 ACTIVE org.eclipse.ecf.osgi.services.distribution_2.0.100.v20111230-0120
18 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin_2.0.100.v20111230-0120
19 ACTIVE org.eclipse.equinox.registry_3.5.101.R37x_v20110810-1611
20 ACTIVE OsgiliathBasicEvolutionaryComponents_1.0.0.qualifier
21 ACTIVE org.eclipse.core.jobs_3.5.100.v20110404
22 ACTIVE org.eclipse.osgi.services_3.3.0.v20110513
23 ACTIVE org.eclipse.osgi.services.remoteserviceadmin_1.0.0.v20111201-0027
24 ACTIVE org.eclipse.equinox.app_1.3.100.v20110321
25 ACTIVE org.eclipse.ecf.provider.r_osgi_3.2.0.v20111230-0120
26 ACTIVE OsgiliathEvolutionaryAlgorithm_1.0.0
27 ACTIVE org.eclipse.core.runtime_3.7.0.v20110110
28 ACTIVE org.eclipse.equinox.common_3.6.0.v20110523
29 ACTIVE ch.ethz.iks.slp_1.1.0.v20111230-0120
30 ACTIVE org.eclipse.ecf.sharedobject_2.2.100.v20111230-0120
And in CONSUMER:
id State Bundle
23 ACTIVE OsgiliathExperimentLauncher_1.0.0.qualifier
24 ACTIVE org.eclipse.osgi.services.remoteserviceadmin_1.0.0.v20111201-0027
25 ACTIVE org.eclipse.equinox.app_1.3.100.v20110321
26 ACTIVE org.eclipse.ecf.provider.r_osgi_3.2.0.v20111230-0120
27 ACTIVE OsgiliathEvolutionaryAlgorithm_1.0.0
28 ACTIVE org.eclipse.core.runtime_3.7.0.v20110110
29 ACTIVE org.eclipse.equinox.common_3.6.0.v20110523
30 ACTIVE ch.ethz.iks.slp_1.1.0.v20111230-0120
31 ACTIVE org.eclipse.ecf.sharedobject_2.2.100.v20111230-0120
Properties set in the Component Declaration of the remote service (host) are:
<property name="service.exported.interfaces" type="String" value="*"/>
<!-- ECF GENERIC -->
<!--<property name="service.exported.configs" type="String" value="ecf.generic.server"/>
<property name="ecf.exported.containerfactoryargs" type="String" value="ecftcp://localhost:3788/server"/> This part works with the appropiate bundles-->
<!-- R-OSGI -->
<property name="service.exported.configs" type="String" value="ecf.r_osgi.peer"/>
<property name="ecf.exported.containerfactoryargs" type="String" value="r-osgi://localhost:3999/server"/>
I also changed the port in r-osgi:// property to other available ports and machine name (evorq). Zeroconf/generic works, but with different bundles, of course (without ch.ethz.*, o.e.e.provider.jmnds/jslp/r-osgi...).
Running in Eclipse Indigo, with the last version of ECF (3.5.4) in Ubuntu with firewall disabled.
Moreover, when finishing the Host console in Eclipse, a "Terminate Failed" window appears, and I have to kill the java process manually (only with this r-osgi configuration).
Thanks in advance!
Re: ContainerConnectException / Connection refused using R-OSGi [message #779866 is a reply to message #779861] |
Mon, 16 January 2012 17:46 |
Markus Kuppe Messages: 177 Registered: July 2009 |
On 01/16/2012 09:35 AM, Pablo Mising name wrote:
> Hi all.
> Quote:
>> 18:04:54.905
>> !MESSAGE
>> returned null for
>> ;children=[]]
>> !STACK 0
>> org.eclipse.ecf.core.ContainerConnectException: at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 9 more
> Quote:
>> id State Bundle
>> 11 ACTIVE
>> 17 ACTIVE
>> 18 ACTIVE
>> 19 ACTIVE
>> 23 ACTIVE
> And in CONSUMER:
> Quote:
>> id State Bundle
>> 11 ACTIVE
>> 17 ACTIVE
>> 18 ACTIVE
>> 19 ACTIVE
>> 24 ACTIVE
> are:
> <!-- R-OSGI -->
> Thanks in advance!
Hi Pablo,
do both host and consumer run on the same machine?
Markus
Re: ContainerConnectException / Connection refused using R-OSGi [message #780566 is a reply to message #780371] |
Wed, 18 January 2012 16:20 |
Geez, I'm idiot. I suppossed that I could specify the desired port in the properties of the component definition. Setting the port to 9278 (R-OSGi default port) in the .xml makes the things work.
Thanks for your help! (and sorry for wasting your time!)
However (and to avoid create another thread), now I realized there are two different imported remote services.
This is a local service implementation that binds other services with target (calculatorType=remote). The idea is to do load balancing with the other services implementations in different machines.
{es.ugr.osgiliath.evolutionary.elements.FitnessCalculator}={calculatorType=distributed, component.name=OsgiliathBasicEvolutionaryComponentsDistributedFitness, component.id=11, FitnessCalculator.target=(calculatorType=daiwal), service.id=72}
Registered by bundle: OsgiliathBasicEvolutionaryComponents_1.0.0.qualifier [20]
Bundles using service:
OsgiliathFunctionsProblems_1.0.0.qualifier [7]
In the local console also there are two other FitnessCalculator service proxies. Only another Equinox console with one remote service implementation has been launched.
{es.ugr.osgiliath.evolutionary.elements.FitnessCalculator}={ecf.rsvc.id=71, calculatorType=remote, ecf.rsvc.ranking=0, component.id=12, ecf.rsvc.cid=r-osgi://evorq:9278, service.uri=r-osgi://evorq:9278#71, ecf.robjectClass=[es.ugr.osgiliath.evolutionary.elements.FitnessCalculator], service.id=71, component.name=OsgiliathFunctionsProblemsFitnessCalculator}
Registered by bundle: R-OSGi Proxy Bundle generated for Endpoint r-osgi://evorq:9278#71_0.0.0 [32]
ch.ethz.iks.r_osgi.remote_1.0.0.RC4_v20111230-0120 [4]
{es.ugr.osgiliath.evolutionary.elements.FitnessCalculator}={component.name=OsgiliathFunctionsProblemsFitnessCalculator, ecf.service.imported.endpoint.service.id=71, ecf.rsvc.ranking=0, service.uri=r-osgi://evorq:9278#71, ecf.rsvc.cid=r-osgi://evorq:9278, calculatorType=remote, ecf.service.imported.endpoint.id=r-osgi://evorq:9278, service.imported=org.eclipse.ecf.internal.provider.r_osgi.RemoteServiceImpl@5a9b8ff9, service.imported.configs=[ecf.r_osgi.peer], component.id=12, service.id=79}
Registered by bundle: org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0.v20111230-0120 [11]
When binding the remote services from the local code, the service.toString() method gives me:
proxy.evorq_jchihb.es.ugr.osgiliath.evolutionary.elements.FitnessCalculatorImpl@7fc4a2d3
and
es.ugr.osgiliath.evolutionary.elements.FitnessCalculator.proxy@org.eclipse.ecf.remoteservice.RemoteServiceID[containerID=r-osgi://evorq:9278;containerRelativeID=71]
So, the first FitnessCalculator service binds this two service proxies via DS, and in both services the code is executed in the remote Equinox. Why I have two different proxies? I think I am exporting the remote FitnessCalculator with two different technologies, but I am not pretty sure.
Using generic/zeroconf only creates an unique proxy.
Re: ContainerConnectException / Connection refused using R-OSGi [message #780967 is a reply to message #780566] |
Thu, 19 January 2012 03:31 |
Don't blame yourself. To some extend you have just been struck by bug
#267521.
> service.id=72}
> [11]
> mailto:proxy.evorq_jchihb.es.ugr.osgiliath.evolutionary.elements.FitnessCalculatorImpl@7fc4a2d3
> and
> mailto:es.ugr.osgiliath.evolutionary.elements.FitnessCalculator.proxy@org.eclipse.ecf.remoteservice.RemoteServiceID[containerID=r-osgi://evorq:9278;containerRelativeID=71]
> sure.
This is indeed specific to the r-OSGi provider and ECF remote service
based on top of it. r-OSGi itself registers a service with the service
registry even without ECF remote service. ECF remote services then also
registers a second service. Just use the one provided by ECF RS.
Markus
Re: ContainerConnectException / Connection refused using R-OSGi [message #780968 is a reply to message #780371] |
and
Re: ContainerConnectException / Connection refused using R-OSGi [message #780969 is a reply to message #780968] |
#267521.
> service.id=72}
> [11]
> and
> sure.
Markus
Current Time: Fri Mar 29 05:22:42 GMT 2024
Powered by FUDForum. Page generated in 0.04788 seconds
