Load Image [message #778483] |
Thu, 12 January 2012 20:09 |
Simon Woelki Messages: 2 Registered: January 2012 |
Hey guys,
When my application starts it opens a image upload.
This works fine. But as soon as it enters the application it throws an error:
at uad.ViewPart4.createPartControl(ViewPart4.java:145)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:534)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:643)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:570)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:272)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:981)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2714)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:3023)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3004)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:799)
at org.eclipse.ui.internal.Workbench$23.runWithException(Workbench.java:1224)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at uad.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Here is the code:
final FileDialog FD = new FileDialog(Display.getCurrent().getActiveShell(), SWT.MULTI);
//FD.setFilterPath("C:\\Users\\Admin\\workspace\\");
String[] filterExt = {"*.jpg", "*.gif", "*.png", "*.jpeg", "*.bmp", "*.*"};
FD.setFilterExtensions(filterExt);
String hans = FD.open();
if (hans != null)
String[] bilder = FD.getFileNames();
String pfad = FD.getFilterPath();
for (int i = 0; i < bilder.length; i++)
String Bild = pfad + "\\" + bilder[i];
ImageDescriptor imageDescriptor = Activator.getImageDescriptor(Bild);
Image orginalImage = imageDescriptor.createImage();
Label label = new Label(linkeSpalte, SWT.RESIZE);
label.setImage(orginalImage);
if (hans == null)
label.setText("Falsches Format oder keine Datei(en) ausgewählt.");
Image orginalImage = imageDescriptor.createImage(); is line 145 (NullPointerException)
Any ideas?
Best regards
Simon
FUDForum. Page generated in 0.03058 seconds
