Home » Eclipse Projects » EclipseLink » criteria builder missing a condition
criteria builder missing a condition [message #778455] Thu, 12 January 2012 14:29 Go to next message
Tom Eugelink is currently offline Tom EugelinkFriend
I'm trying to create a where clause resembling: "stage = ? and approvedby is not null"
This is the builder code:
lCriteriaQuery = lCriteriaQuery.select(lBuyorderRoot).where(
lCriteriaBuilder.and(
lCriteriaBuilder.equal( lBuyorderRoot.get(Buyorder.STAGE_FIELD_ID), Buyorder.STAGE_ENTERED),
lCriteriaBuilder.isNotNull( lBuyorderRoot.get(Buyorder.APPROVEDBYEMPLOYEE_FIELD_ID) )
This is the generated SQL:
SELECT ... FROM buyorder WHERE (stage = ?)
Why is the approvedby missing?
Re: criteria builder missing a condition [message #779903 is a reply to message #778455] Mon, 16 January 2012 19:38 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
Seems to work for me.
Ensure you are compiling and deploying your code correctly. Also ensure you are testing the latest release.
James : Wiki : Book : Blog : Twitter
Re: criteria builder missing a condition [message #779906 is a reply to message #778455] Mon, 16 January 2012 19:38 Go to previous messageGo to next message
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: criteria builder missing a condition [message #780081 is a reply to message #779903] Tue, 17 January 2012 06:26 Go to previous message
I'm 100% certain this is the code being run (debugged it), but I cannot upgrade to 2.3.0 because of a known issue with the embedded ASM.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=358287
This bug also prevents me from upgrading to Java 7, which requires 2.3.0.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=339388
Tom
Previous Topic:Auto generated Id - Optional late binding mechanism
Next Topic:Metamodel not being created until after first use
Current Time: Mon Feb 24 13:09:34 GMT 2020
Powered by FUDForum. Page generated in 0.02652 seconds
