Home » Eclipse Projects » EclipseLink » Query field created by the @OrderColumn(JPQL accessing @OrderColumn automatically generated field)
Query field created by the @OrderColumn [message #778313] Thu, 12 January 2012 10:26 Go to next message
Alessandro Pacifici is currently offline Alessandro PacificiFriend
I have an entity like this:
 public class A {
  @OneToMany
  @OrderColumn(name = "MYORDER")
  private List<B> bList;
I need to fetch from database some B objects ordered by the created MYORDER column.
If I define a field in B like this:
public class B {
  @Column(name = "MYORDER")
  private Integer order;
And I try to query with:
SELECT b FROM B b WHERE ... ORDER BY b.order
EclipseLink try to create the "MYORDER" column 2 times throwing an exception and doesn't create the B table.
I can't fetch A objects because I need to fetch some B objects belonging to different A objects (even no A objects)
How can I solve this?
Alessandro
[Updated on: Thu, 12 January 2012 10:37]
Report message to a moderator
Re: Query field created by the @OrderColumn [message #778357 is a reply to message #778313] Thu, 12 January 2012 15:19 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
By specifying the @OrderColumn(name = "MYORDER") on the OneToMany you are saying that the bList controls that field. I'm guessing that the error you get states that you have two writable fields, or is due to the field already existing.
If you are going to map the MYORDER field within the B object directly, you should be using the OrderBy on the collection instead of OrderColumn and maintain the collection order and the order field yourself.
Best Regards,
Chris
Re: Query field created by the @OrderColumn [message #778623 is a reply to message #778313] Fri, 13 January 2012 14:43 Go to previous message
If you just want the list to be returned ordered, use the @OrderBy annotation instead. OrderColumn causes the field to be controlled by the collection.
Please file a bug though, as the field should not be written twice. Instead, you should get an exception stating that the field is mapped twice (since both the collection and the basic mapping try to write to the field).
Best Regards,
Chris
Previous Topic:automatic persist without cascade, persist replacing entity
Next Topic:Query field created by the @OrderColumn
Current Time: Mon May 25 08:34:22 GMT 2020
Powered by FUDForum. Page generated in 0.01418 seconds
