Re: Shared Workspace [message #778698 is a reply to message #778265] |
Fri, 13 January 2012 16:46 |
Eclipse workspaces themselves are designed not to be shared. They go through an SCM (source control).
But some possible options:
1) each user uses their own workspace, but points their projects or links folders in their projects to the common location. Then they activate the FileSystem refresh preference from Preferences>General>Workspace. There can still be some collision, though, as a refresh picks up another change while a user is adding his own change to a file.
2) some combination of #1 with a remote EFS implementation or RSE from Target Management. I'm not sure how RSE deals with changes from one machine to the common location, it might be last to write on a collision wins.
Really, though, running it through an SCM like git could save you a lot of hassles if you continually get editing collisions.
PW
Paul Webster
FUDForum. Page generated in 0.03470 seconds
