Re: Changing the source [message #776985 is a reply to message #776086] |
Mon, 09 January 2012 16:03 |
I believe the patch in the bug is going to be applied to the source soon.
The code for the pdf emitter is in the
org.eclipse.birt.report.engine.pdf project.
Jason
On 1/7/2012 7:06 AM, Frizz K wrote:
> I want to solve the 276045 bug. How can I modify the source code?
> Which class does it render pdf output?
Re: Changing the source [message #777497 is a reply to message #777369] |
Tue, 10 January 2012 15:49 |
That is correct.
Jason
On 1/10/2012 5:55 AM, Frizz K wrote:
> Ok, so I must modify PDFEmitter.java, I think.
> Then I will compile the project, I will replace PDFEmitter.class in
> org.eclipse.birt.runtime JAR of the BIRT home with my new
> PDFEmitter.class and it musts work, isn't it?
FUDForum. Page generated in 2.28934 seconds
