Reg: rptdesign files getting corrupted [message #775722] |
Fri, 06 January 2012 15:33 |
harip kaligo Messages: 74 Registered: July 2011 |
Member |
We often make some changes to our rptdesign files and in this process observed that the file are getting corrupted. By corrupted i meant that, the changes we make are not getting reflected and the reports are not working as expected.
For ex: we display a report with all the cardholders and their transactions, we observed that after running the report for n number of times and making some changes to meet some business requirements, the rptdesign is corrupted and the column that displays cardholder names , is displaying only one name thru out the report in-spite of no logical error.
We had to redo the report to work as expected.
Is there any limitation on the number of time we generate reports using a rptdesign file.?Does rptdesign gets obsolete using it regularly.
FYI
We are using Birt3.7 version
App server:Web logic 10 in linux.
Jdk:1.5
Db:Oracle
Any help regarding this is appreciated.
KKP
[Updated on: Fri, 06 January 2012 15:45] Report message to a moderator
Re: Reg: rptconfig files [message #775800 is a reply to message #775722] |
Fri, 06 January 2012 17:34 |
No there is no limit. Does the report use parameters to cull the data?
Jason
On 1/6/2012 10:33 AM, kkp Mising name wrote:
> error.
> a rptdesign file.?
> KKP
Re: Reg: rptconfig files [message #776977 is a reply to message #776858] |
Mon, 09 January 2012 15:54 |
I have never seen one get corrupted in the scenario you describe. Is a
rptconfig file for the report being created in the designer? You could
try to delete it.
Jason
On 1/9/2012 6:56 AM, kkp Mising name wrote:
> Jason,
> We don't filter on the data, all the data from query is taken as it
> is.So do you see any issue with report getting damaged or corrupted.
> KKP
Re: Reg: rptconfig files [message #777157 is a reply to message #777024] |
Tue, 10 January 2012 00:22 |
No, they are only created in the designer and store the parameters
values of the last run.
Jason
On 1/9/2012 12:07 PM, kkp Mising name wrote:
> We do have rptconfig files created when we modify the rptdesign files in
> eclipse. But while deploying to linux servers we deploy only rptdesign.
> Do you see any issue with rptconfig files being created.?
> KKP
FUDForum. Page generated in 0.05072 seconds
