Re: Can't have ANT running on new PDT 2.0 [message #89039 is a reply to message #88990] |
Fri, 09 January 2009 14:44 |
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
From within a PDT all-in-one, do this:
Help > Software Updates > Available Software > Eclipse Platform Updates
> [x] Plugin Development Environment (PDE) > install that feature.
IIRC, that's the one that wraps the Ant stuff.
Or, starting from a "Classic" Eclipse (which already has Ant support),
do this to add PDT and its reqs:
http://wiki.eclipse.org/PDT/Installation
N
John G wrote:
> Hi u all !! Salut à tout le monde !!
> I've installed the new PDT 2.0 (pdt-all-in-one-win32-2.0.0GA.zip) and
> noticed that the Ant plugin does not work.
> I cannot make Eclipse to open the AntView (plugin ?) nor I can see the
> Ant tab on Window -> Preferences.
> I have tried to figure out how I can install the missing packages/jar
> with no succes.
> I saw that org.eclipse.ant.ui_3.3.0.v20080529.jar was missing on my
> installation's plugin folder, but
> i got some dependencies errors on the log.
> I give up.
> If anyone has experienced the same (and resolved it), please drop some
> line about your solution/suggestion.
> Greetz !
> -- jOn
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: XDebug JIT Breaking on first line of code [message #91765 is a reply to message #91723] |
Sat, 24 January 2009 01:38 |
Originally posted by: nickboldt.gmail.com
Please provide some background info:
Eclipse version
PDT version
platform type/version (windows/max/linux, 32 or 64 bit, etc.)
java version
XDebug version
where you got PDT from (Eclipse.org or Zend)
Is there by any chance a breakpoint on the first line? Or is the
debugging yakking because it doesn't like the first line of your code?
Matthew Young wrote:
> On Thu, 08 Jan 2009 20:08:11 +0000, Dave Kelsey <dkel50@hotmail.com>
> wrote:
>> Hi Shawn, try going to Window-->Preferences, expand PHP and select debug. Uncheck the box "Break at
>> First Line" and see if that solves your problem.
> I tried that and it didn't change it: still break at the first line.
FUDForum. Page generated in 0.03631 seconds
