Problem with Views using jNetPcap library [message #775284] |
Thu, 05 January 2012 18:06 |
Emad Heydari Beni Messages: 3 Registered: January 2012 Location: Antwerp, Belgium |
My system information:
Ubuntu 11.10
64-bit Architecture
Eclipse (Indigo Service Release 1)
Using jNetPcap wrapper to read network pcap-formatted offline files.
Step by step to face a problem:
- Open the Eclipse, make new Plug-in Project with "Rich Client Platform" check box enabled. (Default template: RCP application with a view)
- Right-click on the project and click properties; then go to the Java Build Path to add the jNetPcap Jar file. Add the Jar file.
- Take a look at the example of reading offline files using jNetPcap which is posted on its website.
- Open the default view to add some codes. (file: View.java) By default, it has a TableViewer with 3 inputs.
- I add my codes to this method of this class:
public void createPartControl(Composite parent) {
viewer = new TableViewer(parent, SWT.MULTI | SWT.H_SCROLL
| SWT.V_SCROLL);
viewer.setContentProvider(new ViewContentProvider());
viewer.setLabelProvider(new ViewLabelProvider());
// Provide the input to the ContentProvider
viewer.setInput(new String[] {"One", "Two", "Three"});
************************* My codes ************************************
final StringBuilder errbuf = new StringBuilder(); // For any error msgs
final String file = "tests/test-l2tp.pcap";
System.out.printf("Opening file for reading: %s%n", file);
* Second we open up the selected file using openOffline call
Pcap pcap = Pcap.openOffline(file, errbuf);
if (pcap == null) {
System.err.printf("Error while opening device for capture: "
+ errbuf.toString());
return;
* Third we create a packet handler which will receive packets from the
* libpcap loop.
PcapPacketHandler<String> jpacketHandler = new PcapPacketHandler<String>() {
public void nextPacket(PcapPacket packet, String user) {
System.out.printf("Received at %s caplen=%-4d len=%-4d %s\n",
new Date(packet.getCaptureHeader().timestampInMillis()),
packet.getCaptureHeader().caplen(), // Length actually captured
packet.getCaptureHeader().wirelen(), // Original length
user // User supplied object
* Fourth we enter the loop and tell it to capture 10 packets. The loop
* method does a mapping of pcap.datalink() DLT value to JProtocol ID, which
* is needed by JScanner. The scanner scans the packet buffer and decodes
* the headers. The mapping is done automatically, although a variation on
* the loop method exists that allows the programmer to sepecify exactly
* which protocol ID to use as the data link type for this pcap interface.
try {
pcap.loop(10, jpacketHandler, "jNetPcap rocks!");
} finally {
* Last thing to do is close the pcap handle
pcap.close();
Continue: Then, I run the project as Eclipse Application and I see this Error stack in console tab of my Eclipse:
!SESSION 2012-01-05 18:49:44.071 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product MyRCProject.product
Command-line arguments: -product MyRCProject.product -data /home/emad/workspace/../runtime-MyRCProject.product -dev file:/home/emad/workspace/.metadata/.plugins/org.eclipse.pde.core/MyRCProject.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.registry 4 1 2012-01-05 18:49:45.977
!MESSAGE Unable to create view ID MyRCProject.view: Plug-in "MyRCProject" was unable to instantiate class "myrcproject.View".
!STACK 0
java.lang.NoClassDefFoundError: org/jnetpcap/packet/PcapPacketHandler
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2406)
at java.lang.Class.getConstructor0(Class.java:2716)
at java.lang.Class.newInstance0(Class.java:343)
at java.lang.Class.newInstance(Class.java:325)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:260)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:63)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:327)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:534)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:643)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:570)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:272)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:981)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2714)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:3023)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3004)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:799)
at org.eclipse.ui.internal.Workbench$23.runWithException(Workbench.java:1224)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at myrcproject.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.ClassNotFoundException: org.jnetpcap.packet.PcapPacketHandler
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
... 66 more
Help: Please help me, let me know if I missed any part in my project.
I should mention that I can read Offline pcap files in normal Java Project.
Source file: is attached to this topic.
[Updated on: Thu, 05 January 2012 18:08] Report message to a moderator
FUDForum. Page generated in 0.03050 seconds
