Home » Language IDEs » Java Development Tools (JDT) » brakepoints in java editor plugin
brakepoints in java editor plugin [message #775236] Thu, 05 January 2012 11:01 Go to next message
Hi!!
this is my first post and I hope you can help me you.
I made a plugin with a java editor. This plugin opens java files compiled with its own version of the Java JDK, not the one with eclipse. It displays any compilation errors that I want.
The problem is that this editor does not allow to put brakepoints or debug on them. I think I miss some dependency but not sure.
If someone could help me would be very grateful.
thanks!!!!
Re: brakepoints in java editor plugin [message #778227 is a reply to message #775236] Wed, 11 January 2012 14:31 Go to previous messageGo to next message
Breakpoints - and the ability to create them in a given editor - are specific to editor contexts. If you are extending the standard Java editor you might only have to add a new IToggleTargetAdapter for your specific editor class. If you have not extended the standard Java editor, you will have to define your own breakpoints / markers / toggle adapters.
For more information, you can look at some of the documents found on our webpage: http://www.eclipse.org/eclipse/debug/documents.php
You can also look at the debug example plug-ins found in the following git repo: http://git.eclipse.org/c/platform/eclipse.platform.debug.git/ (the projects you want to look at are org.eclipse.debug.examples.core and org.eclipse.debug.examples.ui)
Re: brakepoints in java editor plugin [message #780126 is a reply to message #775236] Tue, 17 January 2012 03:34 Go to previous messageGo to next message
Thanks for the answer but I have another question.
My class extends of CompilationUnitEditor because if I extends of JavaEditor I can`t put a breakpoint in the editor when I am in the second environment. I tried to extend the class of JavaEditor and in the second environment, when I open the editor, I can not select the following options: go to annotation, toggle breakpoint and disable breakpoint. For this reason I extends the class of CompilationUnitEditor.
How I add a new IToggleTargetAdapter for my specific editor class, which extends of CompiliationUnitEditor?
[Updated on: Tue, 17 January 2012 03:55] by Moderator
Re: brakepoints in java editor plugin [message #780794 is a reply to message #775236] Thu, 19 January 2012 06:51 Go to previous message
Previous Topic:static field initialization using AST
Next Topic:[SOLVED] Quick Fix via Hovering
Current Time: Wed Jun 18 01:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.07554 seconds
