BIRT 3.7 not show unicode characters [message #775165] |
Thu, 05 January 2012 13:34  |
Lukas A Messages: 3 Registered: January 2012 |
I have deployed BIRT 3.7.1 reports on a Redhat Linux production server in a birt-viewer directory and the problem is that not all unicode characters are displayed, and after failure the left report is blank. Reports are developed on a windows xp x64 machine and I have copied all windows fonts to the linux machine but still the same problem.
Any ideas?
Edit: Forgot to mention that I try to generate pdf, html is ok.
[Updated on: Thu, 05 January 2012 14:56] Report message to a moderator
Re: BIRT 3.7 not show unicode characters [message #775308 is a reply to message #775165] |
Thu, 05 January 2012 18:41   |
Where did you put the fonts on the Linux box?
Jason
On 1/5/2012 8:34 AM, Lukas A wrote:
> I have deployed BIRT reports on a Redhat Linux production server in a
> Any ideas?
Re: BIRT 3.7 not show unicode characters [message #775747 is a reply to message #775537] |
Fri, 06 January 2012 16:06   |
Here is a list of directories that are already in the fontsConfig.xml
<font-paths>
<path path="C:/windows/fonts" />
<path path="d:/windows/fonts" />
<path path="e:/windows/fonts" />
<path path="f:/windows/fonts" />
<path path="g:/windows/fonts" />
<path path="C:/WINNT/fonts" />
<path path="d:/WINNT/fonts" />
<path path="e:/WINNT/fonts" />
<path path="f:/WINNT/fonts" />
<path path="g:/WINNT/fonts" />
<path path="/usr/X/lib/X11/fonts/TrueType" />
<path path="/usr/share/fonts/default/TrueType" />
<path path="/usr/openwin/lib/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/euro_fonts/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/iso_8859_2/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/iso_8859_5/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/iso_8859_7/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/iso_8859_8/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/iso_8859_9/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/iso_8859_13/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/iso_8859_15/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/ar/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/hi_IN.UTF-8/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/ja/X11/fonts/TT" />
<path path="/usr/openwin/lib/locale/ko/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/ko.UTF-8/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/KOI8-R/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/ru.ansi-1251/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/th_TH/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/zh_TW/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/zh_TW.BIG5/X11/fonts/TT" />
<path path="/usr/openwin/lib/locale/zh_HK.BIG5HK/X11/fonts/TT" />
<path path="/usr/openwin/lib/locale/zh_CN.GB18030/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/zh/X11/fonts/TrueType" />
<path path="/usr/openwin/lib/locale/zh.GBK/X11/fonts/TrueType" />
<path path="/usr/X11R6/lib/X11/fonts/TrueType" />
<path path="/usr/X11R6/lib/X11/fonts/truetype" />
<path path="/usr/X11R6/lib/X11/fonts/tt" />
<path path="/usr/X11R6/lib/X11/fonts/TTF" />
<path path="/usr/X11R6/lib/X11/fonts/OTF" />
<path path="/usr/share/fonts/ja/TrueType" />
<path path="/usr/share/fonts/truetype" />
<path path="/usr/share/fonts/ko/TrueType" />
<path path="/usr/share/fonts/zh_CN/TrueType" />
<path path="/usr/share/fonts/zh_TW/TrueType" />
<path path="/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" />
</font-paths>
You can change these but you will have to unjar/rejar it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=362057
or use a system property:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=347431
Jason
On 1/6/2012 3:00 AM, Lukas A wrote:
> Hi Jason, I put them to /usr/share/fonts/default/TrueType/ and then
> rebuild font cache fc-cache -f -v but still no luck
FUDForum. Page generated in 0.10881 seconds
