Re: Birt 3.7 - Frameset mapping crashes my Tomcat server [message #774937 is a reply to message #774932] |
Thu, 05 January 2012 00:16 |
Bertrand,
As a test can you download a stand alone copy of Tomcat? I have the
Birt Viewer installed on the last 3 major releases of Tomcat with no
issues. Do you get any information in the tomcat logs (ie not viewer
logs). Also are you setting the max perm size setting in the JAVA_OPTS
in the catalina.bat file. This should not stop the viewer from starting
but is needed for large reports.
I use:
-XX:MaxPermSize=256m
Jason
On 1/4/2012 7:06 PM, payen bertrand wrote:
> Hello,
> For the last 2 days I have been trying to get "Birt Viewer" being
> working under Tomcat 6.0.30 (I use the Tomcat server delivred with
> Pentaho 3.9). My PC is under Java jdk 6.0.30, Win XP 3, and I'm "admin"
> when I'm testing.
> I followed step by step the installion tutorial (...simple ... well..),
> but nothing to do... when I want to launch the
> "...localhost:8080/WebViewerExample/frameset?__report=test.rptdesign&sample=my+parameter"
> there is only the "menu" displayed, and after a while "Tomcat server"
> crashes.
> Everything seems working fine with "/run" or "/preview" mapping ....but
> there isn't the Ajax menu...
> I tested under "Firefox 8" and "IE 8".
> There is nothing interesting (for me...) in Tomcat's / Birt's Log files,
> even with "ALL" logging option.
> Am I the only person with this problem ? Does somebody have an idea how
> to solve this strange problem ?
> Any clue ?
> Thanks for your help :)
> Bertrand
Re: Birt 3.7 - Frameset mapping crashes my Tomcat server [message #775282 is a reply to message #775194] |
Thu, 05 January 2012 18:02 |
Bertrand,
Are you sure this is not a permission problem?
Jason
On 1/5/2012 9:39 AM, payen bertrand wrote:
> Jason,
> Thanks for your response.
> Tomcat's log (for my last test on Tomcat 7):
> org.apache.axis.utils.JavaUtils isAttachmentSupported
> ATTENTION: Unable to find required classes (javax.activation.DataHandler
> and javax.mail.internet.MimeMultipart). Attachment support is disabled.
> and, in the Localhost_acces_log there is :
> 127.0.0.1 - - [05/Jan/2012:15:18:34 +0100] "GET /WebViewerExample/
> HTTP/1.1" 200 2420
> /WebViewerExample/styles/iv/index.css HTTP/1.1" 404 1073
> It's like if index.css was unreachable...is it important ? (if yes :
> where could I configure its access..)
> And the last log file (named => localhost + date) :
> INFO: ContextListener:
> attributeAdded('org.apache.jasper.compiler.TldLocationsCache',
> 'org.apache.jasper.compiler.TldLocationsCache@14d1d41')
> I have tested under many "stand alone" Tomcat version, from 6 to 7.
> Nothing changed.
> The problem doesn't seems to be coming from memory parameter (I tested
> your indication, and many others, but nothing changed).
> The only things I noticed is that the test report was loading correctly
> when tomcat was running as a Windows's service.
> I'm sure that there is something wrong in my PC config...as nobody on
> Google says having this problem.
> Bertrand
FUDForum. Page generated in 0.03451 seconds
