Re: Greenpages 2.4 not working [message #778384 is a reply to message #778341] |
Thu, 12 January 2012 17:00 |
I've had a look at this and it turns out that their were a few problems. These have all been fixed in the sample and will be available for the next release of Greenpages. Unfortunately it's more than I can guide you through here, the best thing would be to check out the source for the sample from out git repo and try again (http://git.eclipse.org/c/virgo/org.eclipse.virgo.sample-greenpages.git) I've made changes to the code and docs but you would only need to build the doc as an extra as you build the solution as a part of the sample anyway.
This problem is a result of moving to the new Virgo tooling, we missed some renaming in the settings files and there is an extra step to install the 'm2e' plugin in to Eclipse.
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
FUDForum. Page generated in 0.03906 seconds
