Home » Modeling » M2T (model-to-text transformation) » How to get setVariable value back
How to get setVariable value back [message #8018] Wed, 28 March 2007 14:46 Go to next message
Originally posted by: evaandoli.dodo.com.au
Using the setVariable seems to comes out blank when used later on.
I guessing its the way Im reading it back (using {} maybe).
Example Jet is below:
<c:setVariable var="className" select="HelloClass"/>
private {$className} <c:get select="lowercaseFirst($node/@tag)" />;
Re: How to get setVariable value back [message #8141 is a reply to message #8018] Thu, 29 March 2007 04:07 Go to previous messageGo to next message
It seem a bit **** but I got this to work by doing:-
<c:addTextElement select="$node" name="nodeType"
var="nodeTypeText">HelloClass</c:addTextElement>
<c:get select="$nodeTypeText"/>
There is probably a better way so let me know if you find it.
On a slight follow on:-
I then did
private <java:import><c:get select="$nodeTypeText"/></java:import>
Which doesn't resolve the variable before the input statement (anyway that
is what I found) so I just went back to my BIG choose when statement I first
used before trying to be clever.
"Stu" <evaandoli@dodo.com.au> wrote in message
news:eudv42$v0c$1@utils.eclipse.org...
Re: How to get setVariable value back [message #8330 is a reply to message #8018] Thu, 29 March 2007 13:01 Go to previous messageGo to next message
Paul Elder is currently offline Paul ElderFriend
Try:
private <c:get select="$className"/> <c:get
Dynamic XPath expression {$className} only work within attributes of an JET
tag (since you can't but a tag with in a tag).
I am considering doing something like:
But I don't think I can safely use { and } as delimiters - they appear too
often in static text.
My favourite alternative at this point is:
private {{$className}} <c:get select="lowercaseFirst($node/@tag)" />;
I don't think I'll get it in for this release, though. I have submitted a
bugzilla on the idea (https://bugs.eclipse.org/bugs/show_bug.cgi?id=179978).
Feel free to add your comments.
Paul
Re: How to get setVariable value back [message #8392 is a reply to message #8330] Thu, 29 March 2007 13:59 Go to previous messageGo to next message
I had tried the <c:get /> :-
private <c:get select="$className"/>;
But get the following error:
templates/dump.jet(4,9): <c:get select="$className">
Error: XPath expression returned no result
Stuart
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:eugdb5$6rq$1@build.eclipse.org...
> Try:
> JET tag (since you can't but a tag with in a tag).
> (https://bugs.eclipse.org/bugs/show_bug.cgi?id=179978). Feel free to add
> your comments.
> Paul
Re: How to get setVariable value back [message #8483 is a reply to message #8392] Fri, 30 March 2007 07:35 Go to previous messageGo to next message
It also doesn;t work for choose statements so I assume a bug is in the
setVariable when its a containt.
This is a real hassle :-)
<c:setVariable var="returnedRuleType" select="String"/>
<c:choose>
<c:when test="$returnedRuleType='String'">
<c:log>We have a String</c:log>
</c:when>
</c:choose>
news:euggo6$vdf$1@build.eclipse.org...
> Stuart
>> Try:
>> too often in static text.
>> your comments.
>> Paul
Re: How to get setVariable value back [message #8513 is a reply to message #8483] Fri, 30 March 2007 09:25 Go to previous messageGo to next message
A quick work around for this is:-
<c:addTextElement select="$expression" name="string"
var="stringText">String</c:addTextElement>
<c:setVariable var="returnedRuleType" select="$stringText"/>
<c:removeElement select="$expression/string"/>
Off to get the headache tablets.
news:euieki$mae$1@build.eclipse.org...
> <c:choose>
> </c:when>
> </c:choose>
>> Stuart
>>> Try:
>>> a bugzilla on the idea
>>> your comments.
>>> Paul
Re: How to get setVariable value back [message #9841 is a reply to message #8392] Mon, 02 April 2007 12:12 Go to previous message
Stu:
A quick fix: a minor tweak to your code:
<%-- I added spaces in select= for clarity. The essentail difference is the
single quotes around 'HelloClass' --%>
<c:setVariable var="className" select=" 'HelloClass' "/>
An explanation: Without the single quotes, the XPath engine is evaluating
the expression HelloClass, which is equivalent to
../HelloClass. With JET, . maps to the "document", so this is equivalent to
/HelloClass. Odds are that you don't have
an element HelloClass at the root of you input, so className gets set to an
empty node set. The fix makes HelloClass a string - your code should now
work.
FYI: The XPath language can represent boolean, string and numeric values as
well as 'path expressions'. You can set XPath variables to contain any of
these:
<c:setVariable var="vNum" select=" 3 + 6"/>
<c:setVariable var="vString" select=" 'a String' "/>
<c:setVariable var="vBoolean" select=" 3 + 6 = 9 "/>
Paul
> Stuart
>> Try:
>> your comments.
>> Paul
Previous Topic:Re: JET Null Pointer Exception & XPath Axes
Next Topic:Dynamic parameter for a java method defined in the jet file
Current Time: Tue Apr 16 10:58:44 GMT 2024
Powered by FUDForum. Page generated in 0.43528 seconds
