Home » Eclipse Projects » Remote Application Platform (RAP) » Exception in running clientbuilder tool
Exception in running clientbuilder tool [message #773742] Mon, 02 January 2012 12:37 Go to next message
Avrajit Chatterjee is currently offline Avrajit ChatterjeeFriend
Member
I am trying to run the clientbuilder tool as per the usage in https://github.com/ralfstx/rap-clientbuilder. I get the following error. It seems to be searching the 'js' folder while in org.eclipse.rap.rwt all the 'js' files are either in qx, resource,
and respective java packages.
Exception in thread "main" java.lang.IllegalArgumentException: Javascript source directory not found: C:\dev\eclipse-rap-custom\org.eclipse.rap.rwt\js
at org.eclipse.rap.clientbuilder.JsCompressor.main(JsCompressor.java:38)
Am I doing something wrong?
Re: Exception in running clientbuilder tool [message #773749 is a reply to message #773742] Mon, 02 January 2012 12:51 Go to previous message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
which version of RAP are you using? For RAP 1.4 use 1.4-maintenance
branch of the clientbuilder tool. For HEAD use master branch. There *is*
a source folder "js" in the "org.eclipse.rap.rwt" project (CVS HEAD).
Best,
Ivan
On 1/2/2012 2:37 PM, Avrajit Mising name wrote:
> at
Ivan Furnadjiev
Twitter: @EclipseRAP
Previous Topic:E4 Status
Next Topic:Exception in running clientbuilder tool
Current Time: Wed May 29 12:17:00 GMT 2024
Powered by FUDForum. Page generated in 0.04253 seconds
