Cannot connect to the user region of VTS 3.5M1 via remote SSH [message #773269] |
Sat, 31 December 2011 21:44  |
Hi guys
I have a problem when trying to connect to the user region (2502) of VTS 3.5M1 via SSH. It doesn't accept equinox/equinox and therefore I cannot change the credentials and access the Equinox console. Connecting to the kernel region (2402) and changing the credentials does work though. Following are some lines from the log file (not sure if they are of any help).
NioProcessor-6 org.apache.sshd.server.session.ServerSession Session created...
NioProcessor-6 org.apache.sshd.server.session.ServerSession Client version string: SSH-2.0-PuTTY_Release_0.60
NioProcessor-6 org.apache.sshd.server.session.ServerSession Received SSH_MSG_KEXINIT
NioProcessor-6 org.apache.sshd.server.kex.DHG1 Received SSH_MSG_KEXDH_INIT
NioProcessor-6 org.apache.sshd.server.kex.DHG1 Send SSH_MSG_KEXDH_REPLY
NioProcessor-6 org.apache.sshd.server.session.ServerSession Send SSH_MSG_NEWKEYS
NioProcessor-6 org.apache.sshd.server.session.ServerSession Received SSH_MSG_NEWKEYS
NioProcessor-6 org.apache.sshd.server.session.ServerSession Received SSH_MSG_IGNORE
NioProcessor-6 org.apache.sshd.server.session.ServerSession Received SSH_MSG_SERVICE_REQUEST 'ssh-userauth'
NioProcessor-6 org.apache.sshd.server.session.ServerSession Accepting user authentication request
NioProcessor-6 org.apache.sshd.server.session.ServerSession Authorized authentication methods: password
NioProcessor-6 org.apache.sshd.server.session.ServerSession Received SSH_MSG_USERAUTH_REQUEST
NioProcessor-6 org.apache.sshd.server.session.ServerSession Authenticating user 'equinox' with method 'none'
NioProcessor-6 org.apache.sshd.server.session.ServerSession Unsupported authentication method 'none'
NioProcessor-6 org.apache.sshd.server.session.ServerSession Authenticating user 'equinox' with method 'password'
NioProcessor-6 org.apache.sshd.server.session.ServerSession Authentication failed
NioProcessor-6 org.apache.sshd.server.session.ServerSession Closing session
NioProcessor-7 org.apache.sshd.server.session.ServerSession Session created...
NioProcessor-7 org.apache.sshd.server.session.ServerSession Client version string: SSH-2.0-PuTTY_Release_0.60
NioProcessor-7 org.apache.sshd.server.session.ServerSession Received SSH_MSG_KEXINIT
NioProcessor-7 org.apache.sshd.server.kex.DHG1 Received SSH_MSG_KEXDH_INIT
NioProcessor-7 org.apache.sshd.server.kex.DHG1 Send SSH_MSG_KEXDH_REPLY
NioProcessor-7 org.apache.sshd.server.session.ServerSession Send SSH_MSG_NEWKEYS
NioProcessor-7 org.apache.sshd.server.session.ServerSession Received SSH_MSG_NEWKEYS
NioProcessor-7 org.apache.sshd.server.session.ServerSession Received SSH_MSG_IGNORE
NioProcessor-7 org.apache.sshd.server.session.ServerSession Received SSH_MSG_SERVICE_REQUEST 'ssh-userauth'
NioProcessor-7 org.apache.sshd.server.session.ServerSession Accepting user authentication request
NioProcessor-7 org.apache.sshd.server.session.ServerSession Authorized authentication methods: password
NioProcessor-7 org.apache.sshd.server.session.ServerSession Received SSH_MSG_USERAUTH_REQUEST
NioProcessor-7 org.apache.sshd.server.session.ServerSession Authenticating user 'admin' with method 'none'
NioProcessor-7 org.apache.sshd.server.session.ServerSession Unsupported authentication method 'none'
NioProcessor-7 org.apache.sshd.server.session.ServerSession Authenticating user 'admin' with method 'password'
NioProcessor-7 org.apache.sshd.server.session.ServerSession Authentication failed
Can somebody confirm this issue?
On more thing. I was trying to access VTS via remote JMX (JConsole and programmatically) and first it didn't work. Then I figured that JConsole doesn't pick up the truststore until I used the following command line arguments along with JConsole.
jconsole.exe -J-Djavax.net.ssl.trustStore=C:\Java\virgo-tomcat-server-3.1.0.M01\config\keystore
The same problem exists when trying to access Virgo programmatically until I use the following VM arguments.
-Djavax.net.ssl.trustStore=C:/Java/virgo-tomcat-server-3.1.0.M01/config/keystore
Probably it's just some gap in my knowledge but maybe it's worth mentioning it in the user guide anyways.
Frieder
FUDForum. Page generated in 0.05296 seconds
