Home » Modeling » EMF » Programmatic ecore to Java working, but directory structure is strange. Please help?
Programmatic ecore to Java working, but directory structure is strange. Please help? [message #772630] |
Fri, 30 December 2011 08:41 |
Vitor Souza Messages: 2 Registered: December 2011 |
I'm developing an RCP application (check out github.com / vitorsouza / Unagi -- I can't post links, so I had to post it like this) and I want to generate Java source code from an EMF ecore file. Searching the Internet I found a way to do it and it works great, with one exception: I specify the following directory as target for the sources:
/home/vitor/A-CAD/src
And since I set my base package to be it.unitn.disi.acad.models, I expect it to create the following directory structure (A):
/home/vitor/A-CAD/src/it/unitn/disi/acad/model
But instead, it's creating the following strange directory structure (B):
/home/vitor/A-CAD/src/vitor/A-CAD/src/it/unitn/disi/acad/model (note the repetition of vitor/A-CAD/src)
I tried changing some of the parameters that mentioned the target directory, but with no success. I tried debugging so I could understand why it was creating such a strange folder structure, but I couldn't. Can anyone please help? I want to know how to make EMF generate the directory structure that I expect (A).
Below I present a summary of the source code that generates the sources from the ecore model. The complete version can be seen at Github (In the GitHub source, look for it.unitn.disi.unagi.application/src/it/unitn/disi/unagi/application/internal/services/ManageModelsServiceBean.java). Note that in the original code my .ecore file references two other .ecore files, but I removed that from the code below to simplify, assuming that this doesn't have anything to do with my directory structure issue.
// mainEcoreFile = ... (a java.io.File referencing my .ecore file - e.g., /home/vitor/A-CAD/models/acad.ecore)
// targetFolder = ... (a java.io.File referencing the directory where I want the sources to be generated - e.g., /home/vitor/A-CAD/src)
// basePackage = ... (a String with the base package - e.g., "it.unitn.disi.acad.models")
/* STEP 1: .genmodel file generation */
// Initializes the resource set.
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getURIConverter().getURIMap().putAll(EcorePlugin.computePlatformURIMap());
// "Opens" the ecore file and retrieves its package.
IPath mainPath = new Path(mainEcoreFile.getAbsoluteFile().getCanonicalPath());
URI ecoreURI = URI.createFileURI(mainPath.toString());
Resource resource = resourceSet.getResource(ecoreURI, true);
EPackage mainPackage = (EPackage) resource.getContents().get(0);
// Determines the name of the .genmodel file (same as .ecore with different extension).
IPath genModelPath = mainPath.removeFileExtension().addFileExtension("genmodel");
URI genModelURI = URI.createFileURI(genModelPath.toString());
// Creates the genmodel object in memory and sets its attributes.
IPath modelDir = new Path(targetFolder.getAbsoluteFile().getCanonicalPath()).makeRelative();
GenModel mainGenModel = GenModelFactory.eINSTANCE.createGenModel();
mainGenModel.setModelDirectory(modelDir.toString());
mainGenModel.getForeignModel().add(mainPath.toString());
mainGenModel.initialize(Collections.singleton(mainPackage));
mainGenModel.setModelName(mainPath.removeFileExtension().lastSegment());
// Sets the base package in the main package of the genmodel.
GenPackage genPackage = mainGenModel.getGenPackages().get(0);
genPackage.setBasePackage(basePackage);
// Creates the genmodel resource and saves it in the file system.
Resource genModelResource = Resource.Factory.Registry.INSTANCE.getFactory(genModelURI).createResource(genModelURI);
genModelResource.getContents().add(mainGenModel);
resourceSet.getResources().add(genModelResource);
genModelResource.save(Collections.EMPTY_MAP);
/* STEP 2: Java source code generation */
// Creates a null progress monitor to ignore the progress.
IProgressMonitor progressMonitor = new NullProgressMonitor();
// Retrieves the genmodel object from the genmodel resource and checks that it's valid.
GenModel genModel = (GenModel) genModelResource.getContents().get(0);
IStatus status = genModel.validate();
if (!status.isOK()) {
Diagnostic diagnostic = genModel.diagnose();
throw new IllegalStateException("Genmodel file is not valid. Diagnostic message is: " + diagnostic.getMessage()); //$NON-NLS-1$
// Creates a generator from the model and configures the generation.
Generator generator = new Generator(); // Using org.eclipse.emf.codegen.ecore.generator.Generator
generator.setInput(genModel);
genModel.setForceOverwrite(true);
genModel.reconcile();
genModel.setCanGenerate(true);
genModel.setValidateModel(true);
genModel.setUpdateClasspath(false);
genModel.setCodeFormatting(true);
// Generates the source code at the target folder.
IPath path = new Path(modelName);
CodeGenUtil.EclipseUtil.findOrCreateContainer(path, true, path, BasicMonitor.toIProgressMonitor(CodeGenUtil.EclipseUtil.createMonitor(progressMonitor, 1)));
generator.generate(genModel, GenBaseGeneratorAdapter.MODEL_PROJECT_TYPE, CodeGenUtil.EclipseUtil.createMonitor(progressMonitor, 1));
Re: Programmatic ecore to Java working, but directory structure is strange. Please help? [message #774080 is a reply to message #772630] |
Tue, 03 January 2012 08:24 |
Ed Merks Messages: 33140 Registered: July 2009 |
Vitor,
Comments below.
On 30/12/2011 9:41 AM, Vitor Souza wrote:
> Hello,
How are you initializing the GenModel's...
> structure issue.
What's this computing in you situation?
> that it's valid.
> 1)));
Ed Merks
Re: Programmatic ecore to Java working, but directory structure is strange. Please help? [message #945644 is a reply to message #774080] |
Mon, 15 October 2012 13:53 |
Hi Ed,
After more than 9 months, I'm replying to this, so let me start by saying thank you for taking the time to reply to my original post and sorry for not getting back to you. I had to abandon my Eclipse plug-in for a while and recently I've resumed working on it, and on the topic of this post.
So just to give you (and anyone else that ends up here from Google) an update, I decided to revamp my plug-in so it would be based on an Workspace, use Eclipse's file API (IFile, IFolder, IPath etc.) instead of using the RCP just for its integration with other Eclipse plug-ins. This way, I could completely remove the call to CodeGenUtil.EclipseUtil.findOrCreateContainer() and the Java sources were generated from the GenModel in the correct path. Problem solved!
If anyone is interested in the final working code, go to GitHub and append the following path after .com/:
sefms-disi-unitn/Unagi/blob/master/it.unitn.disi.unagi.application/src/it/unitn/disi/unagi/application/internal/services/ManageModelsService.java
Thanks again,
- Vítor
Current Time: Tue Apr 23 17:23:57 GMT 2024
Powered by FUDForum. Page generated in 0.03080 seconds
