[Teneo / JPOX] Spaces with type string [message #88132] |
Thu, 05 July 2007 12:47 |
Originally posted by: fc_supercanard.yahoo.fr
How to put spaces in element of type string using Teneo ?
If there is a space it throws a
org.eclipse.emf.teneo.StoreValidationException and complains that
"The feature 'uniqueName' of ... contains a bad value
Quentin
Re: [Teneo / JPOX] Spaces with type string [message #88195 is a reply to message #88151] |
Thu, 05 July 2007 13:33 |
sure :
org.eclipse.emf.teneo.StoreValidationException: Diagnosis of
MyClassImpl@5d985d98{jpox://?dsname=MyPMF&query1=select from
MyRootElementImpl#db space[OID]MyClassImpl}
'MyClassImpl@5d985d98{jpox://?dsname=MyPMF&query1=select from
MyRootElementImpl#db space[OID]MyClassImpl}' contains a bad value
at
org.eclipse.emf.teneo.resource.StoreResource.validateContent s(StoreResource.java:426)
at org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:360)
CallingClass.save(CallingClass.java:80)
Martin Taal wrote:
> I would need the stack trace to comment on this.
> gr. Martin
>> Regards,
>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #88238 is a reply to message #88210] |
Thu, 05 July 2007 13:58 |
But the type of uniqueName is xs:String. Containing a space in it is not
considered as a bad value from emf... Why Teneo says that it is a bad value?
Martin Taal wrote:
> This is not a Teneo issue. The value of the uniqueName feature is not
> according to its type defined in the ecore model. This is validated by emf.
> gr. Martin
>> sure :
>> at
>> at
>>> gr. Martin
>>>> Regards,
>>>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #88283 is a reply to message #88253] |
Thu, 05 July 2007 14:30 |
You are right, sorry, it is my mistake... In fact the element is of type
xs:ID.
Thanks for help!
Martin Taal wrote:
> It is actually not Teneo who says that it is a wrong value but it is the
> emf validation. Before saving the resource Teneo validates its content
> using a BasicDiagnostic.
> See the methods StoreResource.validateContents and
> StoreResource.validateObject. The StoreValidationException has a method
> getDiagnostics which returns all diagnosed errors in the values.
> I would also check the specific feature in the ecore model to see if it
> has any additional constraints.
> gr. Martin
>> not considered as a bad value from emf... Why Teneo says that it is a
>> bad value?
>>> by emf.
>>> gr. Martin
>>>> sure :
>>>> at
>>>> at
>>>>> gr. Martin
>>>>>> Regards,
>>>>>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #608644 is a reply to message #88151] |
sure :
at
> gr. Martin
>> Regards,
>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #608647 is a reply to message #88210] |
> gr. Martin
>> sure :
>> at
>> at
>>> gr. Martin
>>>> Regards,
>>>> Quentin
Re: [Teneo / JPOX] Spaces with type string [message #608650 is a reply to message #88253] |
xs:ID.
Thanks for help!
> gr. Martin
>> bad value?
>>> by emf.
>>> gr. Martin
>>>> sure :
>>>> at
>>>> at
>>>>> gr. Martin
>>>>>> Regards,
>>>>>> Quentin
FUDForum. Page generated in 0.04702 seconds
