Re: Common Navigator Framework - lazy loading? [message #772634 is a reply to message #772379] |
Fri, 30 December 2011 08:58 |
Michal Borek Messages: 25 Registered: August 2010 |
Thanks for your answer.
Francis I followed this instruction and I have the same problem.
I turned on tracing and after application is started, when i right-click on (empty) navigator, then data is initialized (just like it weren't initialized automatically).
Trace output:
Application Started: 44265 <------ AFTER THIS I RIGHT-CLICKED ON NAVIGATOR
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.OpenActions
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.GotoActions
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.GoIntoActions
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.PortingActions
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.NewActions
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.PropertiesActionProvider
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.WorkManagementActionProvider
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.ResourceMgmtActions
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.UndoRedoActionProvider
Viewer Binding: actionExtension to: org.eclipse.ui.navigator.resources.WorkingSetActions
createContentProvider: Content[org.eclipse.ui.navigator.resourceContent(4) , "Resources"]
Just like it was normal that it is initialized lazily...
[Updated on: Fri, 30 December 2011 09:12] Report message to a moderator
FUDForum. Page generated in 0.03818 seconds
