newbie question: Javadoc for standard JDK API [message #88030] |
Thu, 21 August 2003 22:53 |
Originally posted by: bobo555.hotmail.com
I have seen in the Eclipse user guide and help file that there is supposed
to be little hover window that will display the Javadoc for standard JDK
API . e.g. If I hover over something like "Character.toString()", it will
show me a window that displays the following: "Returns a String object
representing this Character's value. The result is a string of length 1
whose sole component is the primitive char value represented by this
Character object", just like what I would see if I look up the Javadoc for
the JDK API on Sun website. Exactly how do I turn this feature on. I
have the content assist on, which shows me what methods are available for
a specific variable after the dot. I looked everywhere but just cannot
seem to find out how to turn on this feature. It will be really great if
someone can point me to a reference or teach me how to do it. Thanks a
lot!
Re: newbie question: Javadoc for standard JDK API [message #88133 is a reply to message #88030] |
Fri, 22 August 2003 06:27 |
Originally posted by: tom.eicher.gmx.ch.nodomain
You need to have the JRE class library source installed and your JRE
(Preferences->Java->Installed JREs) pointing to it.
-tom
> lot!
Re: newbie question: Javadoc for standard JDK API [message #88463 is a reply to message #88133] |
Fri, 22 August 2003 21:16 |
Thanks for your help, but I still need a bit more info. I went to
Preferences->Java->Installed JREs and my settings is pointing to the right
place to get the Javadoc for the API. The Javadoc DOES show if I do
"Shift+F2" to view it externally (it launches a eclipse browser and go to
the right place in the Javadoc). However, it just wouldn't show in the
little hover window, it'll only show the fully-qualified package path for
the class, but nothing more. How exactly do I make all the info show in
the hover window.
Thanks a lot in advance
> -tom
> > lot!
Re: newbie question: Javadoc for standard JDK API [message #88818 is a reply to message #88463] |
Mon, 25 August 2003 05:24 |
Shift+F2 and the hovers don't take the same input: Shift+F2 will launch
a browser with the Javadoc output generated from source. What you need
for the hovers to show up, is the *source* of the class library. It is
available a vendor / distributor of a JVM, e.g. you can download it from
SUN for the SUN JRE. You can reference the Zip-file from the JRE
preferences.
-tom
> the hover window.
>>-tom
>>>lot!
Re: newbie question: Javadoc for standard JDK API [message #89395 is a reply to message #88818] |
Tue, 26 August 2003 19:19 |
Thank you so much. I finally got it after I tinker with the Java Build
Path settings for my project. Your help is greatly appreciated. =)
> preferences.
> -tom
> > the hover window.
> >>-tom
> >>>lot!
FUDForum. Page generated in 0.02700 seconds
