Home » Archived » EGL Development Tools » Editor(Dojo) problem(EDT closed when Editor(Dojo) dropped in a GridLayout cell)
Editor(Dojo) problem [message #769155] Wed, 21 December 2011 13:48 Go to next message
Daud Ramli is currently offline Daud RamliFriend
I was testing Editor(Dojo) in a RUI handler, I dragged the Editor and dropped it in one of my Gridlayout cell, clicked Ok and suddenly EDT was closed. My EDT version is 0.7.0.v201112071300 and I use WinXP SP3 32bit. I have completed the PaymentFileMaintenance tutorial without any problem.
Re: Editor(Dojo) problem [message #769396 is a reply to message #769155] Thu, 22 December 2011 00:34 Go to previous messageGo to next message
fahua jin is currently offline fahua jinFriend
Member
Daud,
Can you reproduce the problem? What's your default JVM in your system?
Rocky
Re: Editor(Dojo) problem [message #770169 is a reply to message #769396] Fri, 23 December 2011 14:20 Go to previous messageGo to next message
Hi jinfahua,
Yes, I can reproduce the problem. My JVM version is 1.6.0_30.
Thanks.
Re: Editor(Dojo) problem [message #771338 is a reply to message #770169] Tue, 27 December 2011 01:28 Go to previous messageGo to next message
Member
Can you find JVM dump log file under your EDT? If you're using the Sun JVM, then the log file name should be similar to hs_err_pid####.log. Could you please attach the log file to this topic? Thanks.
Rocky
Re: Editor(Dojo) problem [message #771346 is a reply to message #770169] Tue, 27 December 2011 01:54 Go to previous messageGo to next message
Member
One thing I forgot to mention...
The log file should be under the EDT installation directory, such as 'D:\EDT_GA\eclipse' in my machine. Thanks.
Rocky
Re: Editor(Dojo) problem [message #771370 is a reply to message #771346] Tue, 27 December 2011 03:37 Go to previous messageGo to next message
Hi Rocky,
I found the file, pls check the attachment.
Thanks.
Re: Editor(Dojo) problem [message #772114 is a reply to message #771370] Thu, 29 December 2011 02:48 Go to previous messageGo to next message
Member
Daud,
We found similar issue before, but it could not be consistently reproduced so closed the defect (https://bugs.eclipse.org/bugs/show_bug.cgi?id=364058). I just re-opened the defect.
I tried the scenario you described, but could not reproduce it. Could you supply me more detailed information? For example, how many handlers open in the EDT? Or only open 1 handler can always reproduce the problem? Can the problem be reproduced if you do the same operation in an empty new workspace?
If the problem annoys you, you can change the visual editor render engine to IE. Windows > Preference > EGL > Rich UI > Appearance > General > Visual Editor Render Engine > Select 'Trident (Internet Explorer)' > OK, and then reopen the handlers.
Rocky
Re: Editor(Dojo) problem [message #772197 is a reply to message #772114] Thu, 29 December 2011 08:21 Go to previous message
Rocky,
It is Ok now, the problem is solved by changing the Visual Editor Render Engine to IE as you suggested.
Thanks.
[Updated on: Thu, 29 December 2011 08:22]
Report message to a moderator
Previous Topic:XML conversion issue
Next Topic:Extension Point Modeling Framework
Current Time: Tue Apr 16 23:40:38 GMT 2024
Powered by FUDForum. Page generated in 3.07835 seconds
