Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 1.5M4 Redirect using ProtocolMessageWriter
RAP 1.5M4 Redirect using ProtocolMessageWriter [message #769110] Wed, 21 December 2011 12:27 Go to next message
Farooq Kamal is currently offline Farooq KamalFriend
Member
With RAP 1.5 M4 (full implementation of JSON), I cant figure out how to rewrite my existing redirect code for logging out
(with help from Stefan http://www.eclipse.org/forums/index.php/mv/msg/34206/110934/)
final String browserText =
MessageFormat.format("parent.window.location.href = \"{0}\";", urlToLoginPage);
final JavaScriptResponseWriter writer =
ContextProvider.getStateInfo().getResponseWriter();
writer.write(browserText);
The problem is JavaScriptResponseWriter has now been replaced with ProtocolMessageWriter and the code should be
final ProtocolMessageWriter writer =
ContextProvider.getStateInfo().getProtocolWriter();
writer.appendExecuteScript(String target, String scriptType, String code);
I'm looking for what to pass as target and scriptType. The ProtocolMessageWriter also has other methods which can be used but I guess this one should work.
Re: RAP 1.5M4 Redirect using ProtocolMessageWriter [message #769116 is a reply to message #769110] Wed, 21 December 2011 12:36 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
use JSExecutor instead. This class is still internal but there is a bug
opened to make it public:
342995: Provide a public JSExecutor API
https://bugs.eclipse.org/bugs/show_bug.cgi?id=342995
HTH,
Ivan
On 12/21/2011 2:27 PM, Farooq Kamal wrote:
> urlToLoginPage);
> code);
Re: RAP 1.5M4 Redirect using ProtocolMessageWriter [message #769149 is a reply to message #769116] Wed, 21 December 2011 13:39 Go to previous message
Member
Thanks ... works fine!
Previous Topic:RAP 1.5M4 Redirect using ProtocolMessageWriter
Next Topic:dialog in firefox
Current Time: Wed Sep 27 16:38:13 GMT 2023
Powered by FUDForum. Page generated in 0.02176 seconds
