Home » Language IDEs » PHP Development Tools (PDT) » Publishing in new PDT?
Publishing in new PDT? [message #86974] Wed, 17 December 2008 03:46 Go to next message
Nik is currently offline NikFriend
I just downloaded the newest PDT version and was surprised to find no
"Publish files here" option in setting up the debug configuration.
I searched this site and a lot of other sites on how to get your projects
to automatically publish but couldn't get it to work. I tried mapping the
paths for the PHP server but that didn't work either.
Can someone please explain how to perform publishing in the new version?
PS: I don't usually ask questions like this because I'm usually able to
figure it out myself, but I've spent at least an hour trying to get this
to work to no avail. This just points to how complicated the new
publishing feature has been made (bad design).
Re: Publishing in new PDT? [message #86992 is a reply to message #86974] Wed, 17 December 2008 05:45 Go to previous messageGo to next message
Originally posted by: michael.zend.com
There's no publishing facility in new PDT version - it was depreceted.
You can publish your files using RSE.
"Nik " <nik.tech@gmail.com> wrote in message
news:4e4a6292d1bd6039d6797876ea7c8c20$1@www.eclipse.org...
Re: Publishing in new PDT? [message #87399 is a reply to message #86992] Sat, 20 December 2008 16:36 Go to previous messageGo to next message
Originally posted by: lpiernik.gmail.com
I use in pdt 1 aptana plugin. There is synchronization (uploads and
dwonload changed files) with ftp account - great thing.
I was wondering weather it will work in pdt 2... If not can You suggest
a different solution?
Piernik
Michael Spector pisze:
Re: Publishing in new PDT? [message #87414 is a reply to message #87399] Sun, 21 December 2008 07:27 Go to previous messageGo to next message
I see no reasons why this plug-in should not work in PDT 2.0.
Anyway, you can use RSE, as I said, for project synchronization via FTP
(http://www.eclipse.org/dsdp/tm/)
"Piernik" <lpiernik@gmail.com> wrote in message
news:gij6ui$mes$1@build.eclipse.org...
> I was wondering weather it will work in pdt 2... If not can You suggest a
> different solution?
> Piernik
>> Hi,
>>> projects to automatically publish but couldn't get it to work. I tried
>>> mapping the paths for the PHP server but that didn't work either.
Re: Publishing in new PDT? [message #89068 is a reply to message #87414] Fri, 09 January 2009 16:03 Go to previous messageGo to next message
I installed tm but I cannot synchronize - only export...
How can I change help=> install new features to classic way -
Help=>Software updates=>Find and install ?
I don't have general->Capabilities in preferences
>> different solution?
>> Piernik
>>> Hi,
Re: Publishing in new PDT? [message #89127 is a reply to message #89068] Fri, 09 January 2009 17:15 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
As this question keeps coming up, I've placed a stub in the PDT FAQ.
http://wiki.eclipse.org/PDT/FAQ#How_do_I_publish_files_from_ PDT_to_a_server.3F
Please feel free to add to it with perhaps a screenshot and more
information.
Piernik wrote:
>> FTP (http://www.eclipse.org/dsdp/tm/)
>>> suggest a different solution?
>>> Piernik
>>>> Hi,
>>>>> no "Publish files here" option in setting up the debug configuration.
>>>>> tried mapping the paths for the PHP server but that didn't work
>>>>> either.
>>>>> version?
>>>>> able to figure it out myself, but I've spent at least an hour
>>>>> trying to get this to work to no avail. This just points to how
>>>>> complicated the new publishing feature has been made (bad design).
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: Publishing in new PDT? [message #89140 is a reply to message #89127] Fri, 09 January 2009 17:47 Go to previous messageGo to next message
Shawn Clark is currently offline Shawn ClarkFriend
Member
I have been trying to find the right information for the last week.
Everyone points to the fabled "RSE" but in all my readings I haven't
found any documentation on how exactly to set this up. For the most part
the TM / RSE pages only talk about the technology and what it enables
for developers.
The FAQ for RSE always is in regards to the developer except in the
section about "Working with TM / RSE as a User" but even then the
information is vague and not really that helpful.
I know this isn't specific to PDT but as myself and a few others are PHP
developers that are looking for a solution there needs to be something
to help us get started.
I am guessing my scenario is similar to others whereby we are developing
a application on our local machine and then want to get the files to a
web server (i.e. publish to the web server). It is great that RSE allows
us to have FTP and SSH connections to the server and we can see things
within the server. Now how is it possible to setup a build task so that
the task copies files from the local workspace / project to the defined
RSE connection????
I know this is probably something easy for people that are using RSE on
a day-to-day basis but so far I haven't been able to find the spot that
allows this.
Thanks for any information that can assist with this.
Shawn Clark
> information.
> Piernik wrote:
>> Hi,
>>>> Piernik
>>>>> Hi,
>>>>>> either.
>>>>>> version?
Re: Publishing in new PDT? [message #89171 is a reply to message #89140] Fri, 09 January 2009 18:07 Go to previous messageGo to next message
sNop is currently offline sNopFriend
Shawn Clark napsal(a):
> for developers.
> RSE connection????
> allows this.
I'm using Aptanas synchrnize, but this is very important for me too, because upload with
Aptana's synchro is nightmare(sometime).
I have tested RSE few mounth ago, but upload with RSE was worse as Aptana's FTP feature
Re: Publishing in new PDT? [message #89245 is a reply to message #89127] Fri, 09 January 2009 21:08 Go to previous messageGo to next message
> information.
I added a link to the Getting Started documentation for RSE since people
haven't seem to be able to find it. It is included when you install
RSE as well in the help system.
http://dsdp.eclipse.org/help/latest/index.jsp?topic=/org.ecl ipse.rse.doc.user/gettingstarted/g_start.html
Dave
Re: Publishing in new PDT? [message #89260 is a reply to message #89245] Fri, 09 January 2009 21:46 Go to previous messageGo to next message
Member
Read through that document previously when I was hunting around for how
to get things working between my local workstation and a web server.
Unless I missed it, all that documentation just talks about how to get a
connection setup to the server and make it so that you can FTP / SSH
into the box.
Is there anything with RSE that will help PHP developers be able to
publish to the web server without having to manually move files around?
It would be really nice if there was a way to have an ANT script setup
to copy files between a project and an RSE connection but I haven't been
able to find out how to tie in an ANT script with RSE.
Shawn Clark
>> information.
> Dave
Re: Publishing in new PDT? [message #89271 is a reply to message #89260] Fri, 09 January 2009 22:21 Go to previous messageGo to next message
Well, if you have the Ant tools and maybe JDT installed (because I think
the ant editor and launching support still depend on JDT). You can add
an ANT builder to your PHP project. So that it will automatically FTP
it anytime you build.
If you don't want to build it everytime, you could create an ANT script,
and just run that to ftp your project files up to the host system. In
fact I would probably do that, or you can run any other type of Script
to FTP the files up, doesn't have to be ANT.
Dave
> into the box.
> Shawn Clark
>>> information.
>> people haven't seem to be able to find it. It is included when you
>> install RSE as well in the help system.
>> Dave
Re: Publishing in new PDT? [message #89286 is a reply to message #89260] Fri, 09 January 2009 22:32 Go to previous messageGo to next message
I also added the following link:
http://live.eclipse.org/node/567
This is a video walk through on using Remote System Explorer from a
user's perspective.
Dave
Re: Publishing in new PDT? [message #89301 is a reply to message #89286] Fri, 09 January 2009 23:12 Go to previous messageGo to next message
David Carver napsal(a):
> user's perspective.
> Dave
uau, that is great man ;) ;), work this with PDT too ?
And how is it with synchronization ? e.g. i export all files to the remote system, all
files are rewrited(replaced) ? or is there any kind of synchronization ? (time or crc compare)
now i think that i fu*k aptana ftp feature, this looks great great ;)
Re: Publishing in new PDT? [message #89344 is a reply to message #89301] Fri, 09 January 2009 23:52 Go to previous messageGo to next message
Should work the same way with PDT files...they just demonstrated the
functionality using C files.
So yes, if you export it should overwrite the remote system files.
Whatever worked in the C demo should work for PHP files as well.
Dave
>> user's perspective.
>> Dave
Re: Publishing in new PDT? [message #89375 is a reply to message #89344] Fri, 09 January 2009 23:55 Go to previous messageGo to next message
Hi David:
> Dave
thank you for your advices, I want to ask you one question, is planned some kink of
synchronization in feature ?
And how is the difference between RSE and TM ? this two plugins very relate
Re: Publishing in new PDT? [message #89390 is a reply to message #89375] Sat, 10 January 2009 03:49 Go to previous messageGo to next message
TM stands for Target Management, which RSE - Remote System Explorer is a
part of. So yes their Related. Synchronization items, would be best
asked on the target management newsgroup.
Dave
sNop wrote:
> Hi David:
>> Dave
Re: Publishing in new PDT? [message #89439 is a reply to message #89390] Sat, 10 January 2009 16:09 Go to previous messageGo to next message
> Dave
thank you for advices dave, i ask it on tm newsgroup
Re: Publishing in new PDT? [message #89454 is a reply to message #89439] Sat, 10 January 2009 17:24 Go to previous messageGo to next message
If You get answer can You post it here??
sNop pisze:
>> Dave
Re: Publishing in new PDT? [message #89468 is a reply to message #89454] Sat, 10 January 2009 17:36 Go to previous messageGo to next message
Piernik napsal(a):
of course man, but i have problem with RSE, i have tried rse few mounths ago and the same
problem now.
I can't fetch dir, or 1 from 10 fetching hangs with timeout, so import project with 5000
and many folders is impossible for me
I wan to ask you if you have the same problem with rse
thank you for reactions
Re: Publishing in new PDT? [message #89497 is a reply to message #89468] Sat, 10 January 2009 23:53 Go to previous messageGo to next message
I've added the Target Management newsgroup to this thread. They should
be able to answer this question, and any issues with RSE and
synchronization.
Dave
sNop wrote:
> Piernik napsal(a):
> problem now.
Re: Publishing in new PDT? [message #89601 is a reply to message #89497] Mon, 12 January 2009 13:13 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin OberhuberFriend
Hi sNOP,
could we have a bit more information? Like what connection type you use
(I assume ssh)? There are known issues with the way that openSSH
implements some queries, which can lead to "out of handles" errors
on the server.
We're planning to improve the SSH connector for RSE 3.1m5 in terms
of performance, and I think that this improvement should also address
the mentioned openSSH problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256581
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
> synchronization.
> Dave
> sNop wrote:
>> Piernik napsal(a):
>> problem now.
>> project with 5000
Re: Publishing in new PDT? [message #89616 is a reply to message #89601] Mon, 12 January 2009 14:12 Go to previous messageGo to next message
I believe the issue is occurring for sNop with an FTP connection.
Dave
Martin Oberhuber wrote:
> Hi sNOP,
> on the server.
> Cheers,
>> should be able to answer this question, and any issues with RSE and
>> synchronization.
>> Dave
>> sNop wrote:
>>> Piernik napsal(a):
>>> problem now.
Re: Publishing in new PDT? [message #89678 is a reply to message #89616] Mon, 12 January 2009 16:11 Go to previous messageGo to next message
> Dave
you are right it's clear ftp only connection
Re: Publishing in new PDT? [message #89775 is a reply to message #89601] Tue, 13 January 2009 00:22 Go to previous messageGo to next message
Martin Oberhuber napsal(a):
> Hi sNOP,
> on the server.
I have created video, where it's all described.
On the other site is Unix ProFtp in first example and Linux ProFtp 1.3.1 in second example.
In this video you can see, that RSE is for me unusable. You could see every thing in this
video.
I hope and i would be very very happy, if this prbolem would be ficex in next version.
http://rapidshare.com/files/182614377/rse-fetch-problems.7z
Re: Publishing in new PDT? [message #89790 is a reply to message #89775] Tue, 13 January 2009 00:35 Go to previous messageGo to next message
sNop: you might want to open this as a bug/enhancement request for RSE
in the dsdp.tm project. That way it doesn't get lost in the newsgroup.
Dave
>> Hi sNOP,
>> on the server.
> video.
Re: Publishing in new PDT? [message #89805 is a reply to message #89790] Tue, 13 January 2009 00:37 Go to previous messageGo to next message
> Dave
Hi dave bug is already created 260796
Re: Publishing in new PDT? [message #93565 is a reply to message #89468] Thu, 12 February 2009 16:44 Go to previous messageGo to next message
Do You know anything new about synchronization??
sNop pisze:
> Piernik napsal(a):
> problem now.
Re: Publishing in new PDT? [message #93578 is a reply to message #93565] Thu, 12 February 2009 17:07 Go to previous messageGo to next message
Piernik napsal(a):
> sNop pisze:
>> Piernik napsal(a):
>> problem now.
>> project with 5000
This is from TM newsgroup
Hello sNOP,
integration of RSE with Platform Team/Synchronization has already been implemented by a
Student for the Google Summer of Code programme this year, and it's just about to be
integrated into the RSE codebase:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=185925
it will be in with RSE 3.1m5.
Re: Publishing in new PDT? [message #93633 is a reply to message #93578] Fri, 13 February 2009 10:34 Go to previous messageGo to next message
That's great news :)
I've downloaded now pdt 2.1M5.
Do You know how to use it? Is it implemented in PDT 2.1M5 (it should be)
I need synchronization through ftp.
cheers
sNop pisze:
> Piernik napsal(a):
>> sNop pisze:
>>> Piernik napsal(a):
>>> problem now.
>>> project with 5000
> Hello sNOP,
> Cheers,
Re: Publishing in new PDT? [message #93677 is a reply to message #93633] Fri, 13 February 2009 13:07 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
This isn't a feature of PDT. You need to download RSE 3.1M5 which is
part of the Target Management Component of the DSDP project on Eclipse.
http://download.eclipse.org/dsdp/tm/downloads/index.php for downloads.
For more info on Target management see
Dave
> cheers
> sNop pisze:
>> Piernik napsal(a):
>>> sNop pisze:
>>>> Piernik napsal(a):
>>>> problem now.
>>>> project with 5000
>> Hello sNOP,
>> implemented by a
>> just about to be
>> Cheers,
Re: Publishing in new PDT? [message #93692 is a reply to message #93677] Fri, 13 February 2009 13:42 Go to previous messageGo to next message
Oh.
I tried to install it through Help->Install New Software (Ecplise 3.4)
but When I added http://download.eclipse.org/dsdp/tm/updates/3.1milestones/
and checked TM and RSE it says :
Cannot find a solution satisfying the following requirements
org.eclipse.rcp.feature.group [3.5.0.v20090202-9RA1FwwFr-TNqU7GSg_iVTQ].
Ho should I download that depencies?? (In previous version of eclipse it
was much easier :/)
Piernik
Dave pisze:
> Dave
>> cheers
>> sNop pisze:
>>> Piernik napsal(a):
>>>> sNop pisze:
>>>>> Piernik napsal(a):
>>>>> problem now.
>>>>> project with 5000
>>> Hello sNOP,
>>> just about to be
>>> Cheers,
Re: Publishing in new PDT? [message #93707 is a reply to message #93692] Fri, 13 February 2009 14:05 Go to previous messageGo to next message
RSE 3.1 is targeted at eclipse 3.5 so it probably won't work on eclipse
3.4. Try 3.0.2 for eclipse 3.4 this may provide what you want.
Dave
Piernik wrote:
> Oh.
> was much easier :/)
> Piernik
Re: Publishing in new PDT? [message #93722 is a reply to message #93707] Fri, 13 February 2009 14:13 Go to previous messageGo to next message
Oh.
Maybe I have 3.5 :) Galileo is rather 3.5, yes?
In about is 3.4 version but In details is 3.5
I'll gonna try with manual install.
Cheers
Dave pisze:
> Dave
> Piernik wrote:
>> Oh.
>> but When I added
>> it was much easier :/)
>> Piernik
Re: Publishing in new PDT? [message #93777 is a reply to message #93707] Fri, 13 February 2009 23:30 Go to previous messageGo to next message
Hi Dave napsal(a):
> Dave
But 3.0.2 doesn't support synchro or support ? and if not will be 3.0.3 support synchro
feature ? or it will be only on 3.1M5 and next releases ?
Re: Publishing in new PDT? [message #93792 is a reply to message #93777] Sun, 15 February 2009 23:22 Go to previous message
D Kelsey is currently offline D KelseyFriend
Sorry I don't know about the plans of TM (RSE). My comments were based on the fact that the person
was tring to install onto what appeared to be a 3.4 system and they wanted ftp support.
Dave
sNop wrote:
> Hi Dave napsal(a):
>> Dave
Previous Topic:PHP Explorer and Code Assist differences between PDT 1.0.3 and 2.0 releases
Next Topic:problems with breakpoints in xdebug in PDT2
Current Time: Thu Apr 25 22:02:03 GMT 2024
Powered by FUDForum. Page generated in 0.06612 seconds
