Re: [CDO] NPE starting CDO Server with MongoDB store [message #768086 is a reply to message #768056] |
Mon, 19 December 2011 14:55 |
Hi Dan,
I've looked at the code but an explanation does not jump into my face immediately. It's quite some time ago that I
developed the MongoDBStore and I'm not sure if someone uses it. I've not maintained it since and I can not easily
reproduce your problem. I fear you'd have to use the debugger yourself.
Cheers
/Eike
http://www.esc-net.de
Am 19.12.2011 14:53, schrieb Dan Pollitt:
> Hi all,
> I'm looking to test an alternate store implementation for a CDO server (was using the Hibernate store with MySQL) and
> decided to give MongoDB a try.
> After reconfiguring the server however I see the following stack to console before the server exits:
> [ERROR] NullPointerException
> at org.eclipse.emf.cdo.server.internal.mongodb.Classes.getClassifierID(Classes.java:111)
> at org.eclipse.emf.cdo.server.internal.mongodb.Commits.marshallRevision(Commits.java:425)
> at org.eclipse.emf.cdo.server.internal.mongodb.Commits.marshalRevisions(Commits.java:407)
> at org.eclipse.emf.cdo.server.internal.mongodb.Commits.write(Commits.java:382)
> at org.eclipse.emf.cdo.server.internal.mongodb.MongoDBStoreAccessor.doWrite(MongoDBStoreAccessor.java:176)
> at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:150)
> at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:451)
> at org.eclipse.emf.cdo.internal.server.Repository.initRootResource(Repository.java:1461)
> at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1574)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:72)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:99)
> at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:89)
> at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:201)
> at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:110)
> at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
> at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:61)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
> at java.lang.Thread.run(Unknown Source)
> Looks like an NPE during auto-unboxing a null (returned from Map lookup) to an int.
> My cdo-server.xml looks like:
> <cdoServer>
> <acceptor type="tcp" listenAddr="0.0.0.0" port="2036"/>
> <repository name="repo1">
> <property name="supportingAudits" value="true"/>
> <store type="mongodb">
> <property name="uri" value="mongodb://localhost"/>
> <property name="drop" value="false"/>
> </store>
> </repository>
> </cdoServer>
> Is there anything obvious I'm not doing? Or has anyone else seen this?
> Dan
> Relevant version information:
> org.eclipse.emf.cdo (4.0.1.v20110831-1303)
> org.eclipse.emf.cdo (4.0.1.v20110818-0735)
> org.eclipse.emf.cdo.server.mongodb (4.0.0.v20110607-1632)
> org.eclipse.emf.cdo.server.net4j (4.0.1.v20110818-0735)
Cheers
/Eike
FUDForum. Page generated in 0.03159 seconds
