Re: org.w3c.dom.svg broken in Eclipse 3.7? [message #767036 is a reply to message #766653] |
Fri, 16 December 2011 22:30 |
David Williams Messages: 176 Registered: July 2009 |
On 12/16/2011 02:46 AM, Thorsten Meinl wrote:
> Am 15.12.2011 22:39, schrieb Thorsten Meinl:
>> Yes, this seems to fix it. I'm not sure where the old version came from
>> in the first place, but explicitly requiring while creating the target
>> platform the new version fixes everything. Thanks for the hint!
> Ah, now I know. Birt 2.6.2 brings the old version with it. Bummer...
They should have an update for "Indigo" (3.7 platform). If you can
upgrade to that level. You should have
http://download.eclipse.org/releases/indigo/
built-in to your 3.7 environment. Of course, then you might run into other
issues or incompatibilities (updating directly from 3.6 stuff to 3.7
stuff from the repo should work in theory, but its usually discouraged,
since no one tests it.
Or, you could try fresh all-in-one install for
Eclipse IDE for Java and Report Developers
www.eclipse.org/downloads
Good luck,
FUDForum. Page generated in 0.02831 seconds
