Home » Archived » M2M (model-to-model transformation) » [ATL] Reading XML Value(How can I reference a xml element value with the ATL)
[ATL] Reading XML Value [message #765851] Wed, 14 December 2011 19:18 Go to next message
(it may be a stupid question, sorry)
How can I read the node value "DBConnection" from
<Performers>
<Performer>DBConnection</Performer>
</Performers>
Given is the xsd (from XPDL2.1):
<xsd:element name="Performer">
<xsd:annotation>
<xsd:documentation>A String or Expression designating the Performer</xsd:documentation>
</xsd:annotation>
<xsd:complexType>
<xsd:simpleContent>
<xsd:extension base="xsd:string">
<xsd:anyAttribute namespace="##other" processContents="lax"/>
</xsd:extension>
</xsd:simpleContent>
</xsd:complexType>
</xsd:element>
Any help would be great!
[Updated on: Wed, 14 December 2011 19:21] by Moderator
Report message to a moderator
Re: [ATL] Reading XML Value [message #765884 is a reply to message #765851] Wed, 14 December 2011 20:47 Go to previous messageGo to next message
We don't use XSD for modeling; we use Ecore, so perform the XSD to Ecore
conversion to Ecore to see what your converted XSD is like. Then you'll
know what you can access.
Ed Willink
On 14/12/2011 11:19, schabel wrote:
> <Performers>
> </Performers>
> <xsd:annotation>
> </xsd:annotation>
> <xsd:complexType>
> <xsd:simpleContent>
> </xsd:extension>
> </xsd:complexType>
> </xsd:element>
Re: [ATL] Reading XML Value [message #766083 is a reply to message #765884] Thu, 15 December 2011 08:00 Go to previous messageGo to next message
Hi Ed,
thanks. The ecore is below and it only gives access to the attributes.
If the input is:
<Performer Value="DBConnection"></Performer>
...I can pick it.
But is there a way to handle this input?
Kind regards
Gerhard
class PerformerType
attribute Value : _'ecore.xml.type'::String[?] { ordered }
annotation _'<some link>'
name = ':0',
kind = 'simple'
attribute Relationship : _'ecore.xml.type'::String[?] { ordered }
kind = 'attribute',
name = 'Relationship'
attribute AnyAttribute : ecore::EFeatureMapEntry[*] { ordered !unique }
kind = 'attributeWildcard',
wildcards = '##other',
name = ':2',
processing = 'lax'
name = 'Performer_._type',
kind = 'simple'
Re: [ATL] Reading XML Value [message #766283 is a reply to message #766083] Thu, 15 December 2011 13:54 Go to previous messageGo to next message
The EMF project provides a variety of capabilities to read a variety of
different XML styles specifically to help those with non-standard or
legacy XML requirements. I do not need them, so I can only refer you to
the EMF book that I would consult if I needed to use them.
Ed Willink
On 15/12/2011 00:00, schabel wrote:
> Hi Ed,
> If the input is:
> ..I can pick it.
> Kind regards
> Gerhard
> class PerformerType
> name = ':0',
> kind = 'simple'
> kind = 'attribute',
> !unique }
> name = ':2',
> processing = 'lax'
> kind = 'simple'
Re: [ATL] Reading XML Value [message #766449 is a reply to message #766283] Thu, 15 December 2011 20:16 Go to previous messageGo to next message
Hi Ed,
concerning my XML example: its neither legacy nor special, it's frequently used.
(I didn't find it in the ATL manual, shouldn't I?)
Could you please tell me what you mean by "the EMF book"?
Regards Gerhard.
Re: [ATL] Reading XML Value [message #766455 is a reply to message #766449] Thu, 15 December 2011 20:25 Go to previous message
http://www.amazon.com/EMF-Eclipse-Modeling-Framework-2nd/dp/0321331885
Ed Willink
On 15/12/2011 12:16, schabel wrote:
> Hi Ed,
> frequently used.
> Regards Gerhard.
Previous Topic:[ATL] The purpose of Injector and Extractor?
Next Topic:Check duplicates
Current Time: Sun Feb 09 13:01:41 GMT 2025
Powered by FUDForum. Page generated in 0.05951 seconds
