Home » Eclipse Projects » EGit / JGit » Converting cloned project to a Java project (Clone, eGit, Error, Convert, Java)
Converting cloned project to a Java project [message #765730] Wed, 14 December 2011 15:35 Go to next message
Lewis John is currently offline Lewis JohnFriend
After using the eGit plugin to clone the following project [1] into my eclipse Indigo workspace, I am struggling to create any Java packages or classes. When I attempt to, I get "Source folder is not a Java project". When I go to project properties I'm not able to set the Java build path either. Basically I don't know how to convert it to a Java project!
Any help/advice would be greatly appreciated.
Thank you
Lewis
[1] https://github.com/lewismc/sts-transform
Re: Converting cloned project to a Java project [message #765735 is a reply to message #765730] Wed, 14 December 2011 15:44 Go to previous message
A quick update. I found this thread [1]. It helped a lot and thank you very much for the explanation.
lewis
[1] http://www.eclipse.org/forums/index.php/t/262360/
Previous Topic:EGit checkout does not set execute bit correctly
Next Topic:Jgit clone repository
Current Time: Mon Feb 24 14:06:46 GMT 2020
Powered by FUDForum. Page generated in 0.01427 seconds
