Staging view reindexing repository <repo> seemingly stuck [message #765469] |
Wed, 14 December 2011 01:09  |
What is the expected time one should see with the "Staging view reindexing repository <repo>"? I've been working with our new repos now that we've migrated from CVS to EGit, and for some reason within the last 24 hours, my Git Staging view seems to keep causing a never-ending job that is trying to reindex my repository. The repository that is hanging has approximately 700mb of contents so it's large but not enormous and there are a couple other supporting repositories in my workspace.
Unfortunately I can't find much in the way of errors to report, other than the current "reindexing" has been running for 15 minutes. I've a relatively recent MacBook Pro with 4gb of memory that this workspace is running on without any great success.
Basic details include EGit 1.1.0 (originally reproduced with 1.2.0 nightly), Eclipse 3.6.2, Gerrit 2.2.1 configured. When the issue occurs, while the job is there and can block other jobs like builds / saves from happening, my CPU / disk seem relatively idle. I can do a Pull from Upstream fine without issue and have been using the workspace to test the integration with Gerrit for code review.
Thanks for any pointers / hints!
Tim
Re: Staging view reindexing repository <repo> seemingly stuck [message #768309 is a reply to message #765469] |
Mon, 19 December 2011 17:27   |
OK, a few data points:
1 - I don't currently have git installed on the command line. I'm only using jgit + egit from within Eclipse as I was trying to model what I was going to have my dev team also use. If best practices include having command line git installed, I can certainly do so.
2 - I rebuilt my workspace starting with 1.1.0 and I don't see the same issue. Yes, it is slow (maybe 15 seconds to index), but not minutes. When I first setup my workspace, I had cloned the repositories using 1.2.0 and saw the issue on 1.2.0 then downgraded to 1.1.0 and continued to see the problem there. I do not know if this was related to 1.2.0 cloning the repo, or something I had done wrong with my repo.
3 - The size of my repo is approximately 800MB with perhaps 15,000 artifacts in it. I do have a couple other repos of various contents also in my workspace.
Please advise if you would like me to install the git tools on Mac and I will be happy to proceed -- alternatively, if there is regression risk in 1.2.0, I can also see about reproducing under egit 1.2.0 the failure with the sync again. Apologies for not keeping my system in the broken state but it was stopping me from project work.
Cheers and thanks,
Tim
FUDForum. Page generated in 0.06221 seconds
