Re: Subtotal before page break [message #765258 is a reply to message #765116] |
Tue, 13 December 2011 17:50 |
Peter,
I am not sure how you are running the reports, but if you are using two
task run task and then a render task (/frameset servlet mapping on
viewer) you should be able to do this with a page variable and some
script. Look at the attached example. The page variable is used in the
page header and totals the quantity field for each page.
Jason
On 12/13/2011 7:58 AM, Peter Kullmann wrote:
> Hi, how can I display a subtotal before a page break? I have a large
> table that spans over more than one sheet of paper (PDF). We would like
> to show a subtotal at the bottom of every page and a total at the end of
> the table.
> Thanks for any pointers
> Peter
Re: Subtotal before page break [message #765803 is a reply to message #765705] |
Wed, 14 December 2011 17:43 |
Peter,
Currently page variables and pagination manipulation are only supported
with two phase operation,
Jason
On 12/14/2011 9:53 AM, Peter Kullmann wrote:
> Thanks Jason,
> I have a IRunAndRenderTask and assume that this is not going to work
> then (I tried your example in "View Report as PDF" where the totals are
> shown but are one page off). I probably will try to change to a 2 task
> rendering and will then be able to use this.
> Best Regards
> Peter
FUDForum. Page generated in 0.01821 seconds
