Re: Cross-tab issues [message #765256 is a reply to message #765020] |
Tue, 13 December 2011 17:47 |
When it does work (without crosstab) are you tying the data set to a
table? If so can you put the same table above the crosstab and hide it
using visibility?
Jason
On 12/13/2011 4:22 AM, Angel28 wrote:
> I am using eclipse 3.4.2 and BIRT 2.3.2. In a report, I have one dataSet. I have to display a table, a chart and a crosstab. In the fetch(), of the dataSet I have to insert the values of the query in a table in the database. So I am inserting the data in the database and displaying the report.
> The problem is when I am adding the crosstab the insert query is not executing. When I remove the crosstab the insertion works fine. I am doing nothing with crosstab script. I am stuck with this for so long.
> Please help me solve this problem. I am attaching the design file also.
Re: Cross-tab issues [message #768127 is a reply to message #767526] |
Mon, 19 December 2011 16:10 |
Can you move the insert to a different script event. My guess is with
2.3.2 the fetch is being fired earlier do to pre-calculations for the cube.
Jason
On 12/18/2011 3:04 AM, Angel28 wrote:
> I tried to reply several times. But there was problem with my login. Now
> I am back :)
> I have tried putting the cross-tab with and without the table. Same
> result. But for my report, I want the cross-tab, in the table, below a
> chart.
> Hoping to get my problem fixed.
Re: Cross-tab issues [message #768694 is a reply to message #768434] |
Tue, 20 December 2011 16:08 |
If you tie the data set to a table (The table can be hidden) you can use
the onCreate script of the table row. Use:
this.getRowData().getColumnValue("columnname");
Jason
On 12/20/2011 1:19 AM, Angel28 wrote:
> I am inserting the rows which are just fetched from open(). Can I use
> these row values in other script event? Is the row values accessible in
> another script event other than fetch()?
FUDForum. Page generated in 0.03994 seconds
