Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Start a module with a SET parameter
[Acceleo] Start a module with a SET parameter [message #764641] Mon, 12 December 2011 15:22 Go to next message
Timothy Marc is currently offline Timothy MarcFriend
Hi all,
I was wondering, whether it is possible to invoke a main module with a set
of EObjects instead of only one EObject, something like this:
[tempate myModule ( elements : Set(Element))]
[/template]
The generated API of the launcher allows only one single EObject. Can this
be somehow achieved?
Thanks for your hint.
Timothy
Re: [Acceleo] Start a module with a SET parameter [message #765225 is a reply to message #764641] Tue, 13 December 2011 16:53 Go to previous messageGo to next message
The root match condition is a variation point in transformation languages.
I think that, Acceleo iterates over all incoming root objects, so your
incoming set would be transformed element-wise.
Sets are not first class objects, so they are not really eligible for
matching.
I would recommend providing a first class object to contain your set,
otherwise you could live with Acceleo transforming each one by one, but
arrange for a guard so that only the first element produced a result on
behalf of all other elements.
Ed Willink
On 12/12/2011 07:22, Timothy Marc wrote:
> Hi all,
> set of EObjects instead of only one EObject, something like this:
> [/template]
> this be somehow achieved?
> Timothy
Re: [Acceleo] Start a module with a SET parameter [message #765597 is a reply to message #765225] Wed, 14 December 2011 11:07 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Timothy,
The generated launcher is meant to be a simple starting point. It is sufficient for most cases, but it is extensible when you have more complex needs. What you wish to do is possible, but you'll have to customize the launcher in order to call the accuare APIs. Specifically, you should either
  1. Mark the "doGenerate" method "not generated" and change it to call the proper API
  2. Override the "generate" method directly
The "proper API" I mention is "AcceleoService.doGenerateTemplate(Module, String, List<? extends Object>, File, Monitor)" where the list of Object is the actual set of arguments you which to call the template with, instead of the standard "doGenerate" that iterates over the model for a corresponding element. Do not hesitate to ask if the API isn't clear on how to call it, or if you think we could simplify this Smile.
Laurent Goubet
Obeo
Previous Topic:[XPAND] Can't find references to metamodel from template
Next Topic:[Acceleo] How modular is the acceleo architecture?
Current Time: Tue May 17 02:20:23 GMT 2022
Powered by FUDForum. Page generated in 0.02460 seconds
