Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » subclasses not being recreated
Re: subclasses not being recreated [message #86017 is a reply to message #86002] |
Mon, 11 June 2007 18:31 |
I would need some more information to be able to comment. Can you make a small example which shows
this behavior?
gr. Martin
Paul Gardiner wrote:
> Sorry, I forgot to mark it teneo.
> "Paul Gardiner" <pgardiner@syntellect.com> wrote in message
> news:f4k1es$tvr$1@build.eclipse.org...
>> I have a model that is created in java, that gets perisisted fine, but
>> doesn't get recreated when I read it back in.
>> When I create and save an instance of the subclass, and then look in the
>> database, I can see all of its properties in the corresponding table.
>> When I read it back in, the properties from the superclass are ok, and the
>> getter methods work fine. However, the properties that are defined in the
>> subclass are all null.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: subclasses not being recreated [message #86093 is a reply to message #86017] |
Tue, 12 June 2007 19:20 |
Paul Gardiner Messages: 94 Registered: July 2009 |
Member |
I tried recreating and was unsuccessful. It turned out to be a bug in my
implementation classes on my part.
"Martin Taal" <mtaal@elver.org> wrote in message
news:f4k4dg$4da$1@build.eclipse.org...
>small example which shows this behavior?
> gr. Martin
>>> the getter methods work fine. However, the properties that are defined
>>> in the subclass are all null.
> The Netherlands
Re: subclasses not being recreated [message #606901 is a reply to message #86002] |
this behavior?
gr. Martin
The Netherlands
Re: subclasses not being recreated [message #606910 is a reply to message #86017] |
Member |
> gr. Martin
> The Netherlands
Current Time: Thu Apr 25 04:01:55 GMT 2024
Powered by FUDForum. Page generated in 0.03442 seconds
