Home » Archived » EGL Development Tools » Migrating EGL CE projects to EDT
Re: Migrating EGL CE projects to EDT [message #763332 is a reply to message #763326] |
Fri, 09 December 2011 15:29 |
Will Smythe Messages: 41 Registered: July 2009 |
Member |
Kevin - I would start here: http://wiki.eclipse.org/EDT:How_to_move_RBD_app_to_EDT
An EDT "Web 2.0 client with services" project is configured for both Java and JavaScript like a CE project (the client package is setup for JS, server is setup for Java, and common is setup for both). You can put EGL parts that will run on the server in "server" (so, like services), RUI and client-side parts in "client", and common parts (records, common libraries), under "common". Of course, if you already have your own package structure, you can replicate this in an EDT project, and then configure the compiler/generator settings for a package or part via Properties > EDT Compiler.
Re: Migrating EGL CE projects to EDT [message #763333 is a reply to message #763332] |
Fri, 09 December 2011 15:33 |
Aaron Allsbrook Messages: 24 Registered: July 2009 |
Hi Kevin,
I've mainly only migrated RUI project so far. In comparison to other migrations this is simple. I usually have everything standing in under 30 minutes. The big ones are removing the zero from an array declaration and then removing the stereotype of BasicRecord. Mostly its just removing something that are no longer required.
<edit>
oh yeah, I forgot to add, copy and paste your code into a project created in EDT... using the archive import is a lot of wasted time. Just create a new project and copy things into it.
</edit>
[Updated on: Fri, 09 December 2011 15:35] Report message to a moderator
Migrating EGL CE projects to EDT - Joined Record [message #763471 is a reply to message #763326] |
Fri, 09 December 2011 20:43 |
Kevin Tierney Messages: 3 Registered: December 2011 Location: Arkansas |
Thanks for the tips guys.
I was able to join tables in CE using content assist for Record, see code.
What is the corresponding syntax for a join in EDT?
Record EventContacts type SQLRecord
{tableNames = [["contacts", "a"] ,["event_contacts", "b"]],
defaultSelectCondition = #sqlCondition{a.Contact_ICN = b.Contact_ICN},
keyItems=[Contact_ICN, Contact_Name, Contact_Email, event_contacts_Contact_ICN, Event_ID, RuleNo]
Contact_ICN int {column="a.Contact_ICN", isReadOnly=yes};
Contact_Name string {column="a.Contact_Name", isReadOnly=yes, sqlVariableLen=yes, maxLen=30};
Contact_Email string {column="a.Contact_Email", isReadOnly=yes, sqlVariableLen=yes, maxLen=50};
Contact_Cell_No decimal(10) {column="a.Contact_Cell_No", isReadOnly=yes};
Contact_Cell_Service string {column="a.Contact_Cell_Service", isReadOnly=yes, sqlVariableLen=yes, maxLen=30};
Contact_Status string {column="a.Contact_Status", isReadOnly=yes, maxLen=8};
Event_Contacts_Contact_ICN int {column="b.Contact_ICN", isReadOnly=yes};
Event_ID string {column="b.Event_ID", isReadOnly=yes, maxLen=5};
RuleNo int {column="b.RuleNo", isReadOnly=yes};
end
[Updated on: Fri, 09 December 2011 23:06] Report message to a moderator
Re: Migrating EGL CE projects to EDT - Joined Record [message #764633 is a reply to message #763471] |
Mon, 12 December 2011 15:05 |
Joseph Vincens Messages: 31 Registered: December 2011 Location: Prospect CT |
Member |
EDT 0.7.0 does not support syntax to generate a JOIN statement.
You will need to change your record and write an SQL statement to support the JOIN.
Contact_ICN int {@Column {updateable = false}};
Contact_Name string {@Column {updateable = false}};
Contact_Email string {@Column {updateable = false}};
Contact_Cell_No decimal(10) {@Column {updateable = false}};
Contact_Cell_Service string {@Column {updateable = false}};
Contact_Status string {@Column {updateable = false}};
Event_Contacts_Contact_ICN int {@Column {updateable = false}};
Event_ID string {@Column {updateable = false}};
RuleNo int {@Column {updateable = false}};
end
There are a few ways to write an SQL JOIN, here's how I would start the SQL using the record you provided:
GET eventContacts from ds with
#sql{
select
contacts.Contact_ICN, rtrim(contacts.Contact_Name), rtrim(contacts.Contact_Email),
contacts.Contact_Cell_No, rtrim(contacts.Contact_Cell_Service),
rtrim(contacts.Contact_Status), event_contacts.Contact_ICN,
rtrim(event_contacts.Event_ID), event_contacts.RuleNo
from contacts, event_contacts ............complete the JOIN statement
regards,
Joe
Current Time: Fri Apr 19 23:25:53 GMT 2024
Powered by FUDForum. Page generated in 0.04144 seconds
