Exit code = 13 - Again, sorry I cant solve this [message #763305] |
Fri, 09 December 2011 14:37 |
lucas.di.ianni Messages: 4 Registered: December 2011 |
Hi guys,
I know this is a very common error when the user try to inicialize eclipse. I have tried EVERYTHING ( I think ) to solve this problem, but I cant. Ive read the wiki of the .ini archive, the other answers in this forum and other forums but nothing have worked to me.
I ve downloaded this version of eclipse: eclipse-SDK-3.7.1-win32 and this of JDK jdk-7u1-windows-i586 www. oracle .com /technetwork/java/javase/downloads/jdk-7u1-download-513651.html ( both are for 32 bits, I think... ) and I changed the eclipse.ini to this form:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vm
C:\Program Files\Java\jre7\bin\javaw.exe
-vmargs
-Xms40m
-Xmx384m
and then to
-startup
--launcher.library
-showsplash
256m
openFile
-vm
C:\Program Files\Java\jdk1.7.0_01\javaw.exe
-vmargs
-Xms40m
-Xmx384m
and this error persisted.
img850.imageshack.us /img850/9748/error13s.jpg
I dont know what to do more!!!
I want to use Python language...
please someone help me this its very important to me !
[Updated on: Fri, 09 December 2011 14:38] Report message to a moderator
Re: Exit code = 13 - Again, sorry I cant solve this [message #763339 is a reply to message #763305] |
Fri, 09 December 2011 15:41 |
Lucas,
This one's easy.
You failed to notice in the bit on eclipse.ini that, contrary to what
makes perfect sense, the -vm and the C:\Program
Files\Java\jre7\bin\javaw.exe go on SEPARATE LINES.
Yeah, I know, it's pretty silly.
Just replace that one line with these two:
-vm
Best of luck,
Russ
On 09-Dec-11 07:37, lucas.di.ianni wrote:
> Hi guys,
> I cant. Ive read the wiki of the .ini archive, the other answrers in
> -startup
> --launcher.library
> -showsplash
> 256m
> openFile
> -vm C:\Program Files\Java\jre7\bin\javaw.exe
> -vmargs
> -Xms40m
> -Xmx384m
> and then to
> -startup
> --launcher.library
> -showsplash
> 256m
> openFile
> -vm C:\Program Files\Java\jdk1.7.0_01\javaw.exe
> -vmargs
> -Xms40m
> -Xmx384m
Re: Exit code = 13 - Again, sorry I cant solve this [message #763525 is a reply to message #763339] |
Fri, 09 December 2011 23:13 |
hi,
thanks for the help but there is a strange mistake in our messages.
In your quote the comand is in one line, but in my original message it is in differents.
To clarify the things I take a screenshot of the .ini img43.imageshack .us/img43/936/originalxk.jpg
Of course I tried to put your command lines in my .ini, but unafortunately it didnt worked too.
[Updated on: Fri, 09 December 2011 23:13] Report message to a moderator
Re: Exit code = 13 - Again, sorry I cant solve this [message #763547 is a reply to message #763525] |
Sat, 10 December 2011 00:23 |
On 2011.12.09 16:13, lucas.di.ianni wrote:
> hi,
> is in different.
Then it can only be, I think, a mismatch between the bittedness of the
Eclipse you downloaded and the JRE you're using. Perhaps the JRE is for
64-bit?
In fact, if you're running Windows 7, the correct path to your JRE, if
you had downloaded and installed a 32-bit one, would be
C:\Program Files (x86)\Java\jre7\bin\javaw.exe
rather than what you have.
I hope this is your answer.
FUDForum. Page generated in 0.08369 seconds
