Home » Modeling » M2T (model-to-text transformation) » [Xpand] Access EAnnotations
[Xpand] Access EAnnotations [message #763236] Fri, 09 December 2011 11:54 Go to next message
thomas.kipar is currently offline thomas.kiparFriend
I'm writing a generator that generated code out of a ecore model with Xpand. Things work fine... but now, I want to access annotations attachted to operations defined in the ecore model. What I do is:
«IF op.EAnnotations.exists(e|e.source == "test")»
	«LET op.EAnnotations.selectFirst(e|e.source == "test") AS annotation»
	«annotation.details.selectFirst(e|e.key == "body").value»
	«ENDLET»
«ENDIF»
to access details of a given annotation. Actually this works fine when I execute my workflow, however the xpand editor shows an error "Callable not found:Couldn't find property 'value' for type 'Object'" (the editor says annotation.details is of type List[Object].
I can get rid of the problem marker using the following code:
		«annotation.details.typeSelect(ecore::EStringToStringMapEntry).selectFirst(e|e.key == "body").value»
	«ENDLET»
«ENDIF»
... but the codegeneration is not working any more with that code (throwing the excpetion: "EvaluationException : Unknown type 'ecore::EStringToStringMapEntry'").
Even if the first code snipped is working, it is not satisfying to have error markers in my xpand files...
Can anybody figure out whats the problem here? Would be glad if someone could help.
Thomas
Re: [Xpand] Access EAnnotations [message #763302 is a reply to message #763236] Fri, 09 December 2011 14:36 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
should this note be op.eAnnotations (with a lower case e)
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
[Updated on: Fri, 09 December 2011 14:37]
Report message to a moderator
Re: [Xpand] Access EAnnotations [message #763882 is a reply to message #763302] Sat, 10 December 2011 20:18 Go to previous messageGo to next message
Chrstian,
lower case e isn't working for me at all in that case (it says: Callable not found:Couldn't find property 'eAnnotations' for type 'org::eclipse::emf::ecore::EOperation'). As said before, I am able to access the annotations, however I have trouble accessing the details (key-value entries).
Re: [Xpand] Access EAnnotations [message #763887 is a reply to message #763882] Sat, 10 December 2011 20:30 Go to previous messageGo to next message
do you use javabeans metamodel or emf metamodel?
and do you use the same in ide and workflow?
~Christian
[Updated on: Sat, 10 December 2011 20:35]
Re: [Xpand] Access EAnnotations [message #763906 is a reply to message #763887] Sat, 10 December 2011 21:42 Go to previous messageGo to next message
thanks, you got the problem. I used the javabeans metamodel all the time (but started to mix it up with the emf metamodel). If I switch over to the emf metamodel, it should work (I guess). Is there, on the other hand, a way to access the annotation details using the javabeans metamodel?
Re: [Xpand] Access EAnnotations [message #763908 is a reply to message #763906] Sat, 10 December 2011 21:44 Go to previous message
hi,
using a java extension should help you to fix the lacking map support
~Christian
Previous Topic:[Xpand] Questions regarding implementing MetaModelContributor
Next Topic:[XPAND] Can't find references to metamodel from template
Current Time: Sat Mar 06 11:54:23 GMT 2021
Powered by FUDForum. Page generated in 0.02422 seconds
