Home » Eclipse Projects » Remote Application Platform (RAP) » Underlined text in a Label
Underlined text in a Label [message #762986] Thu, 08 December 2011 23:04 Go to next message
Mikhail Nefedov is currently offline Mikhail NefedovFriend
I am using 1.5M2.
I am unable to get underlined text in a Label after I change the Label's font... to be clear -- if I don't use the setFont() I do get the underline.
I created a custom variant in my CSS file:
Label.link {
text-decoration:underline;
I set the custom variant on my label like this:
label.setData( WidgetUtil.CUSTOM_VARIANT, "link" );
Is there something I am missing?
-mikhail.
Re: Underlined text in a Label [message #763109 is a reply to message #762986] Fri, 09 December 2011 07:35 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi mikhail,
the text-decoration is currently supported only by theming. Setting the
new font will remove the decoration. If you need the decoration to be
preserved on the new set font please file an enhancement request.
Best,
Ivan
On 12/9/2011 1:04 AM, mnefedov wrote:
> Hello,
> I am using 1.5M2.
> the underline.
> Label.link {
> Regards,
> -mikhail.
Re: Underlined text in a Label [message #763136 is a reply to message #763109] Fri, 09 December 2011 08:40 Go to previous messageGo to next message
Rüdiger Herrmann is currently offline Rüdiger HerrmannFriend
Mikhail,
to work around this issue you may try to wrap the Label into a Composite
and set the font on this Composite.
HTH
Rüdiger
On 09.12.2011 08:35, Ivan Furnadjiev wrote:
> Hi mikhail,
> Best,
> Ivan
>> Hello,
>> I am using 1.5M2.
>> the underline.
>> Label.link {
>> Regards,
>> -mikhail.
Rüdiger Herrmann
http://codeaffine.com
Re: Underlined text in a Label [message #763282 is a reply to message #763136] Fri, 09 December 2011 13:48 Go to previous messageGo to next message
I need a little more guidance on this. This is what I tried, and it didn't work:
Composite composite = new Composite( parent, 0 );
composite.setFont( a_font );
// composite... layout stuff
Label label = new Label( composite, SWT.CENTER );
// NO FONT SETTING!
label.setText( a_text );
// layout stuff...
Is this what you meant?
-mikhail.
Re: Underlined text in a Label [message #763284 is a reply to message #763136] Fri, 09 December 2011 13:48 Go to previous messageGo to next message
// NO FONT SETTING!
// layout stuff...
-mikhail.
Re: Underlined text in a Label [message #763319 is a reply to message #763282] Fri, 09 December 2011 14:56 Go to previous messageGo to next message
yes, this is what I meant, sorry that it doesn't work. Are you aware of
the Link widget? It can be used to display text with links. The links
are underlined.
Rüdiger
> didn't work:
> // NO FONT SETTING!
> // layout stuff...
> Regards,
> -mikhail.
Rüdiger Herrmann
Re: Underlined text in a Label [message #763335 is a reply to message #763319] Fri, 09 December 2011 15:35 Go to previous messageGo to next message
Yes, I did try the Link widget. The problem is that it doesn't centre properly, and it seems the size calculations are "really" off.
Re: Underlined text in a Label [message #763438 is a reply to message #763335] Fri, 09 December 2011 19:07 Go to previous messageGo to next message
Hm, lot's of dead ends. Sory for that.
Would you mind to open some bugs? One (or rather two) for centering and
wrong size calculations of the Link widget.
And then one for the text-decoration. My current thinking is that it
should be possible to specify text-decoration independently of the font
settings. Hence your initial approach should work.
- Rüdiger
Re: Underlined text in a Label [message #832050 is a reply to message #763438] Thu, 29 March 2012 17:52 Go to previous messageGo to next message
Ronald So is currently offline Ronald SoFriend
I am using the SWT Link class to create a link in my RAP UI.
Link link = new Link(parent, SWT.NONE);
link.setText("<A>Click me</A>");
The link works fine but it is always underlined. How can I disable it through CSS?
I tried:
Link {
    text-decoration: none;
but it's not working.
Thanks!
Re: Underlined text in a Label [message #832081 is a reply to message #832050] Thu, 29 March 2012 18:41 Go to previous messageGo to next message
Hi Roland,
this is currently not possible. We have a bug opened to improve the Link
widget themability:
346438: [Theming][Link] Make Link Widget more themable
https://bugs.eclipse.org/bugs/show_bug.cgi?id=346438
Best,
Ivan
> through CSS?
> I tried:
> Link {
> Thanks!
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Underlined text in a Label [message #832091 is a reply to message #832081] Thu, 29 March 2012 19:01 Go to previous message
Thanks Ivan. I have added myself in the cc list and added my vote on this bug.
Previous Topic:Another &quot;First Open&quot; issue
Next Topic:Help for RAP app deployed in JBoss AS 7?
Current Time: Tue Nov 28 15:22:42 GMT 2023
Powered by FUDForum. Page generated in 0.03187 seconds
