Home » Eclipse Projects » Remote Application Platform (RAP) » Another "First Open" issue
Another "First Open" issue [message #762859] Thu, 08 December 2011 18:14 Go to next message
Arnaud MERGEY is currently offline Arnaud MERGEYFriend
I usually noticed some issue with layout first time the workbench is launched (see 344835 as example)
I found another one with wizard dialog.
I have a snippet to reproduce it,
- start attached snippet.scrolling
- double click on one item of the left view
- double click on one item in the opened editor.
In the dialog only the first group (define) is displayed because the height is greater than expected.
If you close the wizard and reopen it, the dialog is displayed as expected. The issue only occurs for the first open of the dialog.
For 344835 I found a workaround, I have not yet for this one. I have tested in RCP and it works as excpected, so I think it is a bug.
Do you have any idea how I can workaround this ?
Thanks, best regards,
Arnaud
  • Attachment: snippet.zip
    (Size: 46.80KB, Downloaded 115 times)
Re: Another "First Open" issue [message #762862 is a reply to message #762859] Thu, 08 December 2011 18:18 Go to previous message
To illustrate see screenshots, the second Group is missing for the first dialog open, but then is ok for next opens
[Updated on: Thu, 08 December 2011 18:38]
Report message to a moderator
Previous Topic:Bandwidth constraint
Next Topic:Another "First Open" issue
Current Time: Tue Nov 30 18:33:10 GMT 2021
Powered by FUDForum. Page generated in 0.01852 seconds
